Results 11 to 20 of 54
Thread: simplify3d
01-12-2015, 12:29 PM #11
No comparison pictures, but I can offer this comparison -
Make:2015 Shoot Out negative space tolerance test:
Slic3r 1.1.7: Three of five pins removable
Repetier-Host v1.0.6/Cura Engine: Two of five pins removable
Simplify3D v2.2.0: Four of five pins removeable
MakerFaire print-in-place articulated robot 65% model:
Slic3r 1.1.7: All eleven joints operable, but some took some careful teasing to get them working
Repetier-Host v1.0.6/Cura Engine: Only six of the eleven joints were operable, even after teasing
Simplify3D: All eleven joints operable, with little or no teasing needed on the final print
DISCLAIMER: These results are not from a controlled comparison test - for example, different filament ended up being used for each
01-12-2015, 06:16 PM #12
01-12-2015, 06:48 PM #13
- Jul 2014
- Eastern Colorado
- 536
Can S3D save print setting profiles like Slic3r can? That's the only thing keeping me with Slic3r currently, along with the retraction settings as printbus mentioned.
01-12-2015, 07:43 PM #14
- 441
01-12-2015, 10:29 PM #15
- new jersey
- 752
yes you can take any profile and save it. i have a processes folder. i make a process for about every material then i can save and load from there.
01-13-2015, 08:13 AM #16
01-15-2015, 09:15 PM #17
Cura left 3DS right both with out of the box settings
01-16-2015, 03:25 PM #18
- Jan 2015
- 48
big difference there!
01-16-2015, 04:54 PM #19
- Jul 2014
- Eastern Colorado
- 536
It looks like the general shape is better defined by S3D, but the dual extrusion transitions are better on the Cura.
01-16-2015, 05:18 PM #20
What is implied by "out of box settings"? I interpret that to mean no changes to the settings were made at all, but that's not possible. Neither software package is preconfigured to work with two extruders by default, and I'm not sure Simplify3D will even print without some configuration work.
Resin has changed after...
