06-05-2017, 11:18 AM #1
- Jan 2016
Best slicer for Qidi Tech (Replicator Dual Clone)?
I am using currently the Makerbot (3.10.0.1364) software as slicer.
On most of my prints there is a problem with the lower 5-6 mm, primarily if there the part has rounded corners.
I print mostly in ABS at 230C extruder and 110C platform temperature with a medium (0.2mm) resolution.
Anything above this problem-zone comes out OK and has the correct dimensions.
Any suggestions are welcome.
06-05-2017, 12:14 PM #2
- Jun 2016
- Oklahoma
- 904
For free you can try Flashprint. Select the Creator pro as the printer. I have used it a bit to test and seemed to go ok.
Ultimately for ease of use Simplify 3D is probably your best bet but it'll cost you!
I have also worked with Slic3r and got pretty good results so far but it has been a pain to set up, especially if it is new to you.
06-05-2017, 12:58 PM #3
- Jan 2016
Thank you, whirlybird. I will try Flashprint.
