09-17-2023, 10:13 AM #1
- Sep 2023
- 2
Stringing after spending 1 week on calibration
Hey guys,
Its been a week now when I started to fight with ender 5 PRO settings in Cura and Creality Slicers to prevent it from stringing.
Setup:
Ender 5 Pro
eSUN PLA+ Black
0,4mm nozzle
Settings:
60 - bed temp
225 - filament temp
70 - first layer bed temp
0,2mm -layer height
0,2mm - initial layer height
Optimize wall print order - ON
Infill Density - 10%
Print speed - 100
Travel speed - 250
Wall speed - 50
Retraction - 4mm
Retraction speed - 40mm/2
Combining - not in skin
Avoid printed parts when traveling - ON
Avoid support when traveling - ON
Wall ordering - Outside to Inside
Z Seam - Sharpest corner
I have tried to change the settings many, many times with better or worse results but still cannot figurate why some things are happening to the print.
I also printed about 20 calibration models, including temperature towers, stringing pyramids, stringing silos, etc.
I’ve probably changed so many settings that I’m starting to lose track of what does what.
I am sharing my latest photo of stringing test, my current CURA profile and asking you - masters of printing for help, because next I will need to print new hair cause im starting to loose mine…
CURA Profile:https://drive.google.com/file/d/1abzGKXeIaFIFR2ggh28J7dvaimTC2m1o/view
Photo: IMG20230917122240.jpg
Thank you in advance guys!Last edited by Furial; 09-17-2023 at 10:16 AM. Reason: Change source
09-18-2023, 05:59 PM #2
- Sep 2023
- 2
Ok, so i went through this changes:https://www.crealityexperts.com/cali...-3d-printerAnd it solved the problems.Also I dryed the filament.
Hesitation!
07-21-2024, 01:55 AM in 3D Printers (Hardware)
