Results 11 to 20 of 21
09-12-2014, 08:24 PM #11
Viewed the video. It provides a good explanation of the process, however, I have these questions:
1. Where do you define the measurement system. I see that at the end of the process, you can scale in millimetres, but what is the measurement system used in the earlier stages such as when setting depths within the boundaries of the object? (Adding Decoration section)
2. Are our American friends required to use the metric system when the stl file is generated, or can the file be generated in the Imperial system?
3. How would you use this software to create an object such as a rubber duckie like this?
4. Would you add narration to Tutorial 7, please?
OME
09-13-2014, 09:24 AM #12
- Sep 2014
- 10
eXtrudy is an assistant to create things with 2D characteristics in a 3d world. This applies mostly to jewellery, coins, medals etc.. The tool is not able to create real free form 3d objects, but the results should be always printable. Thus it is some kind of 2.5D tool - but for a very special purpose and not for design in general (like professional software as zbrush etc.)
1. Before the last stage the corrdinate system works mostly in pixels. The tool is not meant to allow precise constructions or measurements. Only the last stage should help you to set the volume and bounding box straight. If you need exact scaling, you might post-process the object in another tool like netfabb, meshlab or blender.
2. the metric system rules ;-) - no seriously - at the moment I don't have time for that.
3. You could create a duck-like object with a simple silhouette a a very curved surface profile - maybe add an eye as decoration element. But with the 2.5D you could not model a free from like the mouth or a neck - see the pictures
4. maybe later - can't promise...
09-13-2014, 05:44 PM #13
Great response!
I have produced a medallion, but forgot to save the stl . The result was not up to printing standard because of my inexperience with the software, but the good thing is that I did manage to get a result.
I am going to watch the ankh video again, and write down the step-by-step actions to produce a quick reference document.
OME
09-15-2014, 02:47 PM #14
- Sep 2014
- 10
I'm looking forward to see your results :-)
05-19-2015, 04:51 PM #15
- Sep 2014
- 10
Version 1.2 has been released for Windows with a bunch of new features. And for the first time a Mac OS X version is available!
http://www.extrudy.net/download.html
extrudy_for_mac_os_x.jpgLast edited by eXtrudy; 05-19-2015 at 05:42 PM.
05-22-2015, 01:23 PM #16
- 441
When I tried to download the .exe file, firefox stopped the download with a virus warning. Not sure why, the .zip file downloaded fine, and I ran it through a ton of AV program's all with safe result's. Might want to look into that. Thanks for putting this together for everyone to use though
05-22-2015, 04:35 PM #17
- Sep 2014
- 10
05-22-2015, 05:36 PM #18
- 441
Ever since the first time I tried and got the warning, it won't let me click that link anymore. I tried with Chrome just to check, and it still gives an error. Which is odd, also odd because I use private searching by default with firefox, it should not remember anything when I close it.
Here is a google image I found that looked similar to the one I got, 45.jpg, but I also had a window pop up with it.
05-22-2015, 06:59 PM #19
- Sep 2014
- 10
08-19-2015, 03:43 AM #20
- Jul 2015
- 29
Any version for iphone?
