Results 181 to 189 of 189
Thread: Show your MODS
07-12-2016, 11:37 AM #181
- 134
I have tried PETG twice (different spools) with the same odd results - the first couple of prints come out perfectly. Then all other prints refuse to stick to the bed. I have been really confused by this as it is happening with the exact same gcode as the good prints.
I first tried with blue PETG, then white PETG. When I switch back to PLA Pro everything works fine.
This is what I was printing http://www.thingiverse.com/thing:795954 I printed one set just fine in PETG, and then tried to print a backup and never could get it to stick.
07-21-2016, 08:12 PM #182
- Jul 2016
- 43
You might need to pop it in the oven at 70F to dry it out. It might have just absorbed some moisture.
07-22-2016, 05:48 AM #183
- Nov 2014
- Brevard, NC
- 182
If it is a moisture problem rather than putting it in the oven, you might try heating your 3d printer heat bed to 50 to 70C & placing the roll on the heatbed for a half hour on each side to pull the moisture out. I am not sure what temperature works the best.
07-22-2016, 10:32 AM #184
- 134
This time elapsed between the first two prints that succeed and the following prints that fail is less than one hour - moisture is not the problem.
07-22-2016, 10:41 AM #185
- Jul 2016
- 43
07-22-2016, 12:31 PM #186
07-22-2016, 12:44 PM #187
- Jul 2016
- 43
This used to cause me issues but mainly with layers not bed adhesion. Worth a try checking into.
06-26-2017, 11:24 AM #188
- Mar 2015
- Yes
- 15
Direct drive Prusa i3V with Hexagon hotend
Greetings all,
Here is a little something I fabricobbled over the last couple weeks. I converted my older i3V from the Greg's wade extruder to a direct drive; mostly because I have gone through several of the big spur gears over the last year due to them getting a bit too hot inside the enclosure I am forced to use to keep ABS prints from warping.
It took a bit of tweaking but it works, and much to my chagrin, it works pretty well. I was able to get it working the Hexagon hot end that originally came with the printer. It seems to push 3mm filament ok so far, (I have a lot of 3mm filament that I don't want to waste but will be switching to 1.75 as soon as I run through it all) All in all I'm pretty happy with it and thought I would share.
04-16-2024, 07:41 AM #189
It sounds like moisture to me as well. I may have missed it but have you tired putting some cardboard or something around to create a simple enclosure? That used to help me print and stick a lot.
Going a little off topic, I'm kind of in the same situation as @DrMacZed but a little ahead of him. The extruder mount I used for my Maker Farm was the Itty Bitty and a few years ago it split. I unfortunately had not printed a spare so my machine was kind of out of order. I recently gave it to a student along with about 25-rolls of filament. I didn't want to trash it all but not sure it was even usable. I told him to dry it out well and it might work. I've purchased a Bambu P1S that's 1.75mm so I had no use for the filament. Once he gets the printer working I'll be curious if he has any adhesion issues from moisture still in the old filament.Bambu P1S/AMS
