Results 11 to 20 of 21
Thread: New - can't get started.
Hybrid View
01-24-2021, 03:31 AM #1
- Jan 2021
- 4
I am not familiar with that Printer but the most vital think with all is that the bed is level and the distance between the bed and nozel is correct. Might I suggest that you look on youtube for videos on your printer and bed levelling. Make sure the bed is level and correct before you start using bed adhesive
01-24-2021, 10:40 AM #2
- Aug 2020
- United Kingdom
- 249
Which material you use depends on what you want to do with your printing! PLA is the easiest ! Find a filament that works for you and stick too when you find you need to use a different filament material for good cause only then expand you portfolio otherwise that way madness lies.
01-25-2021, 06:42 AM #3
@axl -
I put a square of thin vellum paper under the mat to raise the center a little.
And yep - stick with pla.
There are only a couple of very specific reasons for ever using abs. And you will most likely find that easier to use filaments like pet or pet-g will do a better job anyway :-)
01-25-2021, 08:05 AM #4
- Aug 2020
- United Kingdom
- 249
If 3d Printing is hobby it unlikely you will find any good reason to use anything but PLA or possibly PET-G other than just trying it to see if you can make it work. If you are using 3D printing commercially the story is different you choose the filament for the job which sometimes makes life much more difficult. In any case find a filament make and material that works for you and stick to it ! Not all PLAs o ABSs etc are the same . For example of the 4 types of ABS we have tried only 2 can be relied upon to print reliably on our set up . Nylon is the same 5 tested 3 work for us.
01-29-2021, 05:52 AM #5
@ gambo - 3 nylons ?
Which ones are they ?
I find that taulman 225 (245 ?) works well and mymat nylon from italy - work well in an unheated enclosure. But everything else had no luck with at all.
Taulman bridge is one of the worst - but, as mentuioned this is all in an unheated build volume.
01-29-2021, 06:24 AM #6
- Aug 2020
- United Kingdom
- 249
Hi If it is any help I use Spectrum PA6 LW Taulman 230 and I have to say Taulman Bridge. I use that at 260C first Layer 255C following layers and a 60C bed 70mm/S I don't use bridge often I preferer Taulman 230 for soft nylons printed at 255C all layers with 55C bed.
Spectrum PA6LW I really like it is a hard nylon which gives a very good finish. I print that a nominal 260C other wise as the Tauman 230.
When I started with the nylons I fiddled around with a lot of different beds including several of the much praised proprietary beds but came down to using Tufnol Sheet lightly sanded ( re-sanded very rarely) with no coating at all but cleaned every print with Acetone.
I have made a lot of valve assembly parts this way including some designs 30mm high 15 mm dia but only having the periphery 1 or 1.5 in contact with the bed plate using a skirt. No adhesion problems ith either 230 o PA6LW.
Bigger items Large vessel tops with integrated valves 75mm by 30mm have printed in PA6LW without any sign of warping.
In an enclosure but un heated
01-29-2021, 09:14 AM #7
Hmm search for 'Spectrum PA6LW' turns up exactly no matches.
where do you get that from ?
Taulman 230 c !
That's the fella :-)
01-30-2021, 07:12 AM #8
- Aug 2020
- United Kingdom
- 249
Hi Spectrum Filaments in Poland make it http://en.spectrumfilaments.com
search for Poliamide_Nylon-PA6-Low-Warp
I buy it direct from them .
01-31-2021, 10:28 AM #9
- Jan 2021
- 6
How do you convert STL to Gcode.
01-31-2021, 10:38 AM #10
- Jan 2021
- 3
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
