Results 1 to 8 of 8
  1. #1
    Angry Can't get driver to install...
    Hi, I just got this printer and am having problems getting it to work. I have the M3D Micro+
    When I run the slicer, it says... No printers found...
    Please help.
  2. #2
    Engineer Roberts_Clif's Avatar
    Jun 2017
    Location
    Washington State, USA
  3. #3
    I did this 4 times already... still no luck.
  4. #4
    Jun 2017
    Location
    If you Have Windows...
    Look in the Support Downloads and click through the folders until you come to the "Click here to browse all versions". Select Windows.
    Select M3D Drivers 2017.03.27.zip last file in the folder list for windows download. Unzip for Folder M3D Drivers 2017.03.27.
    Contains
    M3Dv2.Cat
    M3D_v2.inf
    dpinst_amd64.exe
    dpinst_x86.exe
    m3d_install.bat
    Choose the dpinst that fits your windows and install dpinst_x86 for 32bit windows dpinst_amd64 for 64bit windows.
  5. #5
    I got it to work! I have a question though... when i tell it to move to home position, it runs into the walls and vibrates... is this normal?
  6. #6
    Jun 2017
    Location
  7. #7
    How come the first layer is always thick and sloppy?
  8. #8
    Also... I thought this thing had mesh leveling... when i calibrate it, it only calibrates the center of the plate.
