Results 1 to 8 of 8
Thread: Can't get driver to install...
Hybrid View
01-12-2019, 06:58 PM #1
- Jan 2019
- 6
Hi, I just got this printer and am having problems getting it to work. I have the M3D Micro+
When I run the slicer, it says... No printers found...
Please help.
01-13-2019, 06:38 AM #2
I would reinstall the Software.
https://support.printm3d.com/760750-...e-M3D-Software
01-13-2019, 08:07 AM #3
- Jan 2019
- 6
I did this 4 times already... still no luck.
01-13-2019, 11:00 AM #4
If you Have Windows...
Look in the Support Downloads and click through the folders until you come to the "Click here to browse all versions". Select Windows.
Select M3D Drivers 2017.03.27.zip last file in the folder list for windows download. Unzip for Folder M3D Drivers 2017.03.27.
Contains
M3Dv2.Cat
M3D_v2.inf
dpinst_amd64.exe
dpinst_x86.exe
m3d_install.bat
Choose the dpinst that fits your windows and install dpinst_x86 for 32bit windows dpinst_amd64 for 64bit windows.
01-13-2019, 11:13 AM #5
- Jan 2019
- 6
I got it to work! I have a question though... when i tell it to move to home position, it runs into the walls and vibrates... is this normal?
01-13-2019, 12:18 PM #6
https://www.thingiverse.com/groups/m...ral/topic:7957
Youtube has a few video's this is one
https://www.youtube.com/watch?v=2GQNxRIs8K0
01-13-2019, 02:44 PM #7
- Jan 2019
- 6
Also... I thought this thing had mesh leveling... when i calibrate it, it only calibrates the center of the plate.
01-13-2019, 02:42 PM #8
- Jan 2019
- 6
How come the first layer is always thick and sloppy?
ABS Sticking to Build Plate
