Results 1 to 8 of 8
Thread: Pegasus Z-coupler
Hybrid View
06-20-2016, 11:03 PM #1
- Oct 2014
- 31
Pegasus Z-coupler
Has anyone used z-couplers on their 12" pegasus? I have clearance issues with the lower x-axis extrusion when I trying to use them on the Z rods. I am having issues with the rods slipping with the stock plastic tubing, but I can't see how I can use the z-couplers without doing major modifications to the printer.
06-21-2016, 10:00 AM #2
- Apr 2014
- 37
I actually thought of using couplers instead of the tubing, just because vinyl tubing looked inappropriate for the job, but it's been fine for me so far.
If I may suggest to use these: http://tinyurl.com/hcu59py
Don't have to be from the same seller but a 5mm to 5mm should do the trick.
I'm not sure where you would need to modify anything.
It should be a plug and play type of situation.
what's causing the Z rod to slip?
06-21-2016, 11:16 AM #3
OVersliders - I don't have a Pegasus, but the issue has been raised before. Apparently the Pegasus doesn't have the clearance for that type of coupler. No alternative was identified in the earlier thread.
The plastic tubing couplers tend to lose their grip with use, especially when warm temperatures start softening the tubing.Last edited by printbus; 06-21-2016 at 11:24 AM. Reason: added link to earlier thread
06-21-2016, 01:20 PM #4
I don't know whether the MakerFarm build guides mention it, but adding zip ties around the tubing usually helps minimize slipping. Use two zip ties over the motor shaft and two zip ties over the threaded rods if you can. Tighten them as tight as you can - perhaps pulling the free end with a pliers before snipping it off.
06-21-2016, 05:52 PM #5
- Jul 2014
- 305
I am using a coupler on my Pegasus successfully.
I used longer bed springs and longer M3 bouts for the bed and raised the bed the 3-5mm needed to allow the use of couplers.
I am at work currently but I can provide pictures later if you would like?
06-22-2016, 12:00 AM #6
- Oct 2014
- 31
06-22-2016, 09:50 PM #7
- Jul 2014
- 305
I had like 3-4 other solutions but they required a lot of work, so I decided on this method.
I also though about using spacers under the springs, but I thought the springs may kick the spacers out during a print and unlevel the bed. I found the longer springs at a Ace Hardware and paid about $2.00 for a full set of springs.
06-21-2016, 11:59 PM #8
- Oct 2014
- 31
Qidi X Plus 3 Paper thin first...
05-27-2024, 01:15 AM in General 3D Printing Discussion
