Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Engineer
    Dec 2014
    Canada
    Share your Top 3 Tips
    I think it would be great if those of you who have been involved in 3D printing for a while could share your best tips. in hindsight. from issues you had and things you have learned.
    Here are mine.
    1. Makes changes via the Arduino firmware. disable chitchat in Marlin
    2. PEI Bed OMG this stuff is awesome for adhesion
    3. PetG filament.. forget ABS, or PLA. PEtG is the best.. doesn't warp, is strong, prints well, and is food safe
    4. Bondtech Extruder.. awesome
    5. Fan on Control board. on stepper drivers
    6. Simplify3D made my life easier
    7. Alum Bed with Borsilicate glass
    8. Auto bed levelling is great once you get it tuned
    9. Run from SD card. so many failures due to weird USb connectivity from PC
    10. PID Heating for Bed, helps keep things consistant, not hard to implement
    Please share your learnings
    1. When trying to fix an issue change ONE THING AT A TIME and then test that change to see if it helped.
    2. Do NOT use PLA parts in an enclosure....learning this the hard way right now.
    3. Learn your firmware.
    1) use the right material for the job. hi-temp pla is available, but polycarbonate might suit better. Massive selection of filaments - think about what you use for each model and make sure it's suited to your particular printer.
    2) learn about 3d printing BEFORE you buy a machine.
    3) chat box on a forum is NOT a search box ;-)
    4) gluesticks are your best friend :-)
    Technologist
    Nov 2014
    Brevard, NC
    I had not seen the Bondtech Extruder before. How do you mount that on your i3v? Do you use directly on the X-Carriage or as Bowden style?
    Quote Originally Posted by PyramidDave View Post
    Generally speaking I have mostly seen people use them in a Bowden configuration.
    Engineer-in-Training
    Jun 2014
    Glass bed
    PETG
    Cold pulls
    Not too strong idler tension
    Engineer
    Dec 2014
    Canada
    Quote Originally Posted by Carrot_or_Stick View Post
    This is one way. but they offer several mounts that you can adapt. I currently use a vertical mount that connects right into the gantry plate
    http://www.thingiverse.com/thing:1036770/#files
  8. #8
    Quote Originally Posted by adamfilip View Post
    Very nice! Where did you source your lead screws from? I have a bent guide rod and i'm looking to upgrade.
  9. #9
    Engineer
    Dec 2014
    Canada
    From Ebay. but you can get some from Openbuilds part store
    http://openbuildspartstore.com/8mm-m...me-lead-screw/
    antibacklash nut
    http://openbuildspartstore.com/anti-...me-lead-screw/
  10. #10
    antibacklash nut
    Thank you!
