Results 601 to 610 of 4110
03-18-2016, 02:56 PM #601
- Feb 2016
- Texas
- 18
g-code with updates from forum to eliminate glob and replace with line
Left:
; **** Replicator 2X start.gcode ****
M73 P0 ; Enable build progress
G162 X Y F3000 ; Home XY maximum
G161 Z F1200 ; Home Z minimum
G92 Z-5 ; Set Z to -5
G1 Z0 ; Move Z to 0
G161 Z F100 ; Home Z slowly
M132 X Y Z A B ; Recall home offsets
M135 T1 ; Load left extruder offsets
G1 X-110 Y-75 Z30 F9000 ; Move to wait position off table
G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating
M126 S[fan_speed_pwm] ; Set fan speed
M140 S[bed0_temperature] T0 ; Heat buildplate
M134 T0 ; Stabilize bed temperature
M104 S[extruder1_temperature] T1 ; Heat left extruder
M133 T1 ; Stabilize left extruder temperature
G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs
G92 A0 B0 ; Zero extruders
G1 X-100 Y-65 F9000 ; Move to front left corner of bed
G1 Z0.3 F6000 ; Move down to purge
G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed
G1 X100 Y-65 F180 ; Wait for ooze
G1 X110 Y-65 F5000 ; Fast wipe
G1 Z1 F100 ; Lift
G92 A0 B0 ; zero extruders
M73 P1 ;@body (notify GPX body has started)
; **** end of start.gcode ****
Right:
G1 Z0 ; Move Z to 0
M135 T0 ; Load right extruder offsets
M104 S[extruder0_temperature] T0 ; Heat right extruder
M133 T0 ; Stabilize extruder temperature
G1 X100 Y-70 F9000 ; Move to front right corner of bed
G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed
G1 X-100 Y-70 F180 ; Wait for ooze
G1 X-110 Y-70 F5000 ; Fast wipe
G1 Z0.5 F100 ; Lift
Both:
G1 Z0 ; Move Z to 0
M133 T0 ; Stabilize right extruder temperature
G1 Z0.5 F100 ; Lift
G1 Z1 F100 ; Lift
Take the above and put it in the start script for each mode (Left only, right only, both)
03-18-2016, 04:51 PM #602
- Feb 2016
- Texas
- 18
Has anyone tested the top Z-Axis size with the 1/4 Glass Build Plate?
I have a tower I want to upscale to 145.2 mm, but if you minis the 6.35 mm (.25 inches) it leaves only 143.65 mm.
03-18-2016, 05:23 PM #603
All good choices to start with.
I've replaced my hood and now have my spools overhead.
http://www.criticalmods.com/
03-18-2016, 06:57 PM #604
- Feb 2016
- 57
03-18-2016, 07:10 PM #605
03-18-2016, 07:13 PM #606
- Feb 2016
- 57
03-18-2016, 10:48 PM #607
- Feb 2016
- 57
This is so unbelievably frustrating. I have done everything according to the instructions, and since nothing in the instructions explains how to change the temperature of the build platform in ReplicatorG, I used the mess of instructions you can find online. The printer moves to front left corner and finally heats to the proper temperatures, then goes to the back right corner, then goes back to the front left corner, and starts heating up to the wrong temperatures again. What am I doing wrong?
Edit: Okay, so apparently this program appends to the .x3g file. I thought it was overwriting, so no wonder this was happening. It probably would have reheated 20 more times if I hadn't stopped it. It's printing pretty good now.
This is one of the most buggy and strangely developed programs I've used. I especially like how it looks to see where your desktop folder is to determine the location of your Windows user profile. I would say using one of the global variables would have made a bit more sense haha.Last edited by dspdrew; 03-19-2016 at 12:12 AM.
03-18-2016, 11:31 PM #608
If using S3D go back and reload the Flashforge creator pro original profile and start with it's default settings.
Don't worry about the how the startup script works it won't hurt anything.
Try printing a cube with the defaults. Then when you have that working you can try the more advanced settings.
BTW I was able to print 90% of your model but the top point is to small for a .4 nozzle.
03-19-2016, 12:03 AM #609
- Feb 2016
- 57
03-19-2016, 01:51 AM #610
