Results 1 to 5 of 5
Thread: Solid Layers Rough
06-29-2015, 07:56 PM #1
Solid Layers Rough
Hey Guys,
I have an issue that I cant quite figure out. My solid layers are coming out rough and extruding a bit. I calibrated my e steps and am within 1 mm. I also have "fine tuned" the flow rate using a hollow cube and is within .01 however the solid layers (except for the first layer) look as if I am over extruding or the layers are overlaping to much. I am using a .3 nozzle with .4 layer width and .2 layer height, 2 perimeters, 3 bottom/top layers, printing in ABS at 230. I am using S3D. Any help would be greatly appriciated.
06-30-2015, 04:02 AM #2
06-30-2015, 05:48 AM #3
15%. on that part there is only about 3 layers of infil due to how tall it is, however this happens on parts that are much much taller as well, with smaller and larger infill percentages. Onething that I thought about while in bed last night, is this seems to only happen on diagonal lines, where both x and y axises are involved. Im curious if there is an issue with my y axis somewhere. In what way, im not sure, the belt tension is proper (IMHO)
06-30-2015, 07:09 AM #4
It's tough to see many issues for me in that photo. If I wasn't happy with the surface, I'd lightly sand and acetone to smooth it out.
07-01-2015, 12:03 AM #5
After playing with the flowrate with a few calibration cubes, I found i was extruding 3% to much, enough to cause a shotty top layer.
Today, 07:24 AM in 3D Printer Parts, Filament & Materials
