Results 1 to 10 of 51
09-22-2019, 12:20 PM #1
MOSFET is the name of the correct part you need here. Because PWM circuits need to be solid state or they will wear out and fail. And solenoids are mechanical in nature so they will not respond well to the pulses of power. I personally am a big fan of the ones made by MKS as they seem to come with the largest heatsinks. You can also use one to drive a heater cartridge for your extruder if you like. They are cheap. Here is a fleabay ad for one: https://www.ebay.com/itm/3D-Printer-...UAAOSwv-ZZ5lXX
09-25-2019, 05:32 AM #2
- Jul 2017
- 184
You can actually use a solenoid relay, it uses what's sometimes called Bang-Bang control rather than a PID loop with PWM. It basically involves turning the heater fully on and switching it off as it approaches the target temperature, then switching it on as the temperature drops. It's a lot cruder and the temperature is less stable since the heater is either off or going full tilt, you can't turn it on just a little for fine adjustment. It is usable if you're on a tight budget like OP says they are, but they're also wanting to use profiled linear rails so that's sending some mixed messages.
09-25-2019, 08:04 PM #3
So for those who understand electronics when we energize a coil and then release the power what we get is a serious voltage spike. This effect is called a "collapsing field" and it is the stored energy in the windings of the coil quickly searching for a path to ground. It is also how spark plugs get their power to bridge an air gap in an engine's combustion chamber. It's how we can achieve Kv from 12v. By energizing a coil and then releasing the ground. And that collapsing field can generate so much power it can jump an air gap, or arc through plastic or an ignition wire if it needs to but that spike is so powerful it will find ground. To PWM or otherwise rapidly switch power to a coil is to constantly and repeatedly in fast or even a less fast fashion apply this affect to the controlling circuit. And it won't live long. We don't PWM solenoids or relays with coils. Solid State Relays ONLY for PWM, pal.
09-25-2019, 08:31 PM #4
- Jul 2017
- 184
09-25-2019, 08:54 PM #5
09-25-2019, 09:16 PM #6
- Jul 2017
- 184
It's not really a "frequency", it's switching fully on/off at a specified threshold. It has nothing to do with frequency it's always either full on, or full off depending on what side of the threshold your sensor is measuring. There is no regular, repeated pulse of varying width (or duty cycle) which makes PWM. This bang-band control how most ovens, hot water cylinders etc work. The time between switching is not pre-determined (unlike PWM, where each pulse is a fixed duration, just with varying on time) and the time between switching is measured in minutes if not longer. Even if the switching time was regular, if your period is measured in minutes or even seconds I don't think anyone will call that PWM. Have a look at the wikipedia page for bang-bang control.
https://en.wikipedia.org/wiki/Bang%E2%80%93bang_control
09-26-2019, 01:07 AM #7
- Sep 2019
- 18
Thanks, but i will probably just go with a mosfet because its more suited for the job. When i say I'm on a budget i just mean that I don't have an unlimited budget and if I wanted to spend a ton on a printer i would just buy one already made. I have several printers already so i don't want a cheap crappy printer that can just print. I want a really nice quality print and a large print volume and am willing to spend the money on things that make a difference like linear rails and maybe even genuine Hiwin or equivalent as I have heard they are worth the money. Its sometimes a challenge figuring out what will really be worth spending on but there are certain things I know will help. anything that makes it run smoother basically so belts, bearings, pulleys, stepper drivers, linkages etc will not be where i will look to save.
I just want to be smart about where i spend the money. A perfect example is the SKR board. It was like $30 CAD compared to a duet or others for $150-$300. I bought a clone E3D V6 but bought the genuine block sock and thermistor kit and hope to replace the heat break soon as well. I may stick to the 24V heatbed just to keep the costs down but may buy the 120v depending on how the budget is doing.
Power stuff I will stick to what is safe and made for the purpose. life span of electronics is related to proper power regulation as well as heat dissipation and duty load etc. I always use decent power supplies and components as it saves a lot of time and money in the long run.
09-26-2019, 01:46 AM #8
- Jul 2017
- 184
Linear rails aren't bad, but I feel like it's a bit of a sledgehammer to swat a fly scenario. Lots of printers with round rails produce great results, even ones that are indistinguishable from those made on printers with linear rails. It's up to you, but I feel that many people go for linear rails because for the same reason they like to buy fancy cars. At the end of the day you're squirting molten plastic from a 0.4mm bore, and 0.2 is considered a good fitting tolerance, if your round rail can't hold that tolerance it's bent. The biggest practical advantage linear rails have on a 3D printer is that they can be fully supported, so on longer spans there isn't the bendy and flexible bit in the middle that can wobble under inertial forces (or sag if its not appropriated sized, but the rails on a delta are vertical so they wont sag).
This is even more so the case with idlers, pulleys and belts, the cheap stuff from china works fine and is manufactured to much higher tolerances than your printer will be outputting. Belts can sometimes cause problems from what I've heard with the rubber wearing off the belt, or not having fibre reinforcement but I've never run into these issues myself. Any difference someone claims between a chinese idler bearing and a name brand one is entirely in their head.
I don't know how much money, if any, you'll save buying a 24V bed vs line voltage, but at that size/power requirement I can virtually guarantee you'll spend more money than you saved on a 24V power supply that can handle that much current.Last edited by Trakyan; 09-26-2019 at 01:56 AM.
09-26-2019, 11:13 AM #9
Man you are chock full of great advice. The linear rails get bolted to the frame every inch or so whereas the rods mount through holes only at the very ends of the rods and the entire length of rod can flex and the holes can get loose and then the rods themselves can move not the bearing against the rod. That is why we all upgrade to the linear rails. Because it stops the z wobble completely even with less than perfect leadscrews. You should just read more on this forum and try to limit the amount of advice you are giving here.
09-26-2019, 03:54 PM #10
- Jul 2017
- 184
Again, I already mentioned the bending, and that the rails can be fully supported which prevents that. My point was just that there are plenty of printers that get good results with rods. You can't say "we all upgrade to linear rails", we don't all do that because cost is a concern, and there are a lot of other ways to get rid of z wobble. Plus, the OP is building a delta with belts so the the z wobble you get from a bent screw is irrelevant.
@reefsider
As for crunchy bearings, it wont influence your print unless it takes you a cheater bar to turn the bearing. Cleaning and re-oiling the bearings will make them run a bit smoother if really bothers you, but your printer wont care. If you're worried about belt stretch you should go for steel core belts not name brand aramid or glass fibre ones. In that case even the cheapest Chinese belt that might skimp on the reinforcement will do fine. For such a big delta with long belts steel core might be well worth considering, just make sure you pick the right pulleys and idlers so you don't end up with broken reinforcement in a few weeks.Last edited by Trakyan; 09-26-2019 at 04:03 PM.
