Thread: Corner curling up
08-04-2015, 02:58 PM #1
- Feb 2015
- 371
Corner curling up
I am having issues with the corner of one of prints curling up. It is symmetrical design and the opposite corner is fine. After watching the print it appears that this is where the layer change is happening. Is there a way to clean this up? A wipe move? What is causing this? Retraction setting too high, not enough?
09-05-2015, 05:59 AM #2
- Feb 2015
- 70
The issue could be a slight amount of filament leaking out during the z-axis lift.. ?? Perhaps try a slightly lower tempurature... do you have any filament oozzing out of the nozzle right before it gets up to temp?
Most slicers have a setting to randomize seam position. Slic3r has it for sure, if that is what you are using. That might be worth a try.
I have some curling problems as well on most parts with overhangs. No idea why. I've only ever tried printing with PLA thusfar, what material are you using?
09-05-2015, 09:45 AM #3
- Feb 2015
- 371
PLA. I tried a different slicer and it is better. Matter Control works a lot better for this but has issues in other areas. Every Slic3r seems to be a compromise.
I did get a little bit of oozing which is very evident when I set it to random seams. I am using a e3dv6 with 1.5mm retractions. The retraction is a bit on the hight side for that hotend i think. Most of the ooze is after a travel move. I think there is just too much pressure in the melt zone. I am thinking a 1.75 setup may be in my future.
09-05-2015, 12:13 PM #4
- Feb 2015
- 211
09-05-2015, 03:07 PM #5
- Feb 2015
- 371
Not for that print. I recently added one to my printer and haven't ran that particular print yet.
09-05-2015, 10:15 PM #6
- Feb 2015
- 211
09-12-2015, 06:22 AM #7
- 349
