Results 1 to 9 of 9
06-26-2014, 05:40 PM #1
- 462
See the blue highlighted bits below? You've got some holes in your mesh.
06-27-2014, 03:08 AM #2
- Burnley, UK
- 1,662
Thanks for that. I had been all over it looking for the problem but when I stick it at the same angle as your picture I can see them. As the upper set and the lower set are just copies of each other then it must be a bug in Freecad.
This is indeed disheartening as I will have to redraw it in something else. :bawling:
06-27-2014, 05:39 AM #3
06-27-2014, 08:10 AM #4
- Burnley, UK
- 1,662
06-27-2014, 10:48 AM #5
I don't know what you did to create the design... But when I run into this problem it is usually because I put two things so their edges are at the same location, but they don't intersect. Suppose I want to stick two 1x1x1 cubes together. If I put one at the origin and one at (1,0,0) I am going to have one face of each cube in the same location, but not actually intersecting. This has cause me problems again and again. If I put one at the origin and one at (.9999,0,0) everything will be fine.
