Results 1 to 9 of 9
10-18-2015, 12:10 PM #1
- Sep 2015
- 9
I'm sorry, but which filament gear works for you?
The newer aluminum one or the older steel one?
10-18-2015, 01:19 PM #2
- Sep 2015
10-18-2015, 03:46 PM #3
Curious, is the aluminum gear Larger diameter than the steel one, ?
It appears to be, but it may not be larger where the Teeth are ?
If it is larger diameter at teeth, that may explain why it works better ?
Or was the steel-tooth gear clogged with filament, making it slip ?
(I normally clean that gear after about 25 prints, to remove residue,
and Flex-filament would require it be cleaned more often)Last edited by EagleSeven; 10-18-2015 at 03:59 PM.
10-18-2015, 09:54 PM #4
- Sep 2015
- 9
Thanks for the response. I have the alum one as well, I am betting the sharper pointed steel one was cutting in and grabbing the TPU, then pulling it around...
