Results 1 to 10 of 15
10-10-2015, 05:52 AM #1
Software change request / new features
Hi Sintratec team,
I would like to list here a couple of changes i would like to see implemented in the current software (1.0.27):
1- the coil target temperature and IR lamps target temperature should be saved when closing the software so we don't have to re-enter them next time
2- same for laser scanning speed. I forgot to change it from default 250 and my print was melting. YOu should maybe change the default from 250 to 400 if you cannot save our last parameter.
3- can you add an APPLY Powder button to the screen where we monitor temperatures ? this way we don't have to change screen when applying the first 5 layers before a print session
4- is there an easy way for you to add the possibility of changing lamp power factors WHILE printing ? at present we can only change them in config file and have to re-start printer each time. Would be great to do this on the fly when calibrating the printer.
5- i don't see any STOP Printing button , is there one ? How can we stop the printer before the end of the printing job ?
6- would be nice to have a PAUSE printing button also.
7- YOu should display the number of the current layer being printed. The % is not enough
8- Is it a big work to compile your software for 32 bits windows ? At present i have only one 64 bit computer so it's difficult to have it tied up when printing. I have 2 other older laptops but all 32 bits.
9- Possibility to display how much powder there is left in the powder chamber
thanks for your feed-back,Last edited by Hugues; 10-10-2015 at 06:33 AM.
10-12-2015, 12:10 PM #2
- Oct 2015
Thanks for your great suggestions!
Good Idea, put it on feature requirements of 1.0.28
Already implemented for 1.0.28 - both now with saving and default set to 350 (your previously entered speed value gets automatically communicated to the printer each time a print is started, if you forgot to set the speed manually by pushing the button).
Already implemented for 1.0.28: There's a new paramter, number of empty layers before print (so that the applying of the first 5 layers gets done automatically).
Still a good idea to add the button to the "4. print" pane, I put it on the feature requirements list.
That is a good input but out of scope for now since it involves deeper changes to the printer firmware (put it on the feature request list).
There actually is a STOP button in 1.0.27, on the print pane, left of the progress bar. I took note that it's not visible enough. But in 1.0.28 the STOP button will temporarily be removed since there's a firmware bug resulting in being unable to start a new print after pressing STOP (defeating the STOP button's purpose).
The PAUSE button is right besides the STOP button. Fix in 1.0.28: Pressing PAUSE again will resume the print
Already implemented for 1.0.28.
There will be a 32 bit support soon, but for now we focus on the 64 bit version. Arguably we could have gone 32 bit only, but the 3D stuff and slicing benefit tremendously from 64 bit. I could post here once we have an early 32 bit version...
We know about the necessity of that one, but that's something that would require work on the firmware and is not possible immediately.
Now about the printer firmware, we have a huge rework coming up. We've taken all feedback we've got so far (if someone reads this and has more, please post ) and tons of improvements from our side (much more sophisticated temperature control, better motor motions, complete new low-level and reliable USB communication and so one). It'll be done in about 4 weeks (We've got less frequent firmware updates compared to desktop software since deployment is an hassle).
1.0.28 update will be pushed by the end of the week btw.
Thanks again for your input. Cheers!
Dominik form SintratecLast edited by Dominik; 10-13-2015 at 09:17 AM.
10-12-2015, 12:46 PM #3
10-13-2015, 09:12 AM #4
- Oct 2015
There you go:
10-13-2015, 12:57 PM #5
Oh ! Silly me. A few weeks ago i was trying these buttons, i thought they were used to switch on/off the coil for the heater and the IR lamps.
Now i see the Pause and Stop buttons, sorry.
You might want to write Pause and Stop on them, or show a tool tip. Might help newbies, like me :-)
thanks a lot, i'll try them next time i print.
11-05-2015, 11:12 AM #6
- Nov 2015
- 12
I can't seem to get the software to install. I keep getting an error and the install quits without completing. Any suggestions?
11-05-2015, 11:19 AM #7
11-05-2015, 11:23 AM #8
- Nov 2015
- 12
Yes 64bit Windows 10 on an Intel i3 dual core. 6GB of RAM, 1TB hard drive. Brand new machine. Connected to the internet via WiFi.
Error reads, "The Sintratec Central Setup Wizard ended. Sintratec Central setup ended prematurely because of an error. Your system has not been modified. To install this program at a later time, please run the installation again. Click the 'Finish' button to exit the Setup Wizard."
11-05-2015, 11:33 AM #9
11-05-2015, 11:41 AM #10
- Nov 2015
- 12
Yes, already submitted. The website isn't very clear, but maybe the software is only running on Windows 7? Unfortunate considering that software is six years old and Windows 10 has been available since July. I have no access to Windows 7 computers and had to buy this one, which is my first Windows computer since Win95 on a Sony Vaio.
Thanks for trying.
