Results 1 to 10 of 29
12-31-2014, 10:02 AM #1
- Dec 2014
- 42
I picked up Simplify3D for my powerspec, but I can't seem to get it to work properly. The prints come out 10x better with ReplicatorG, and I'm not sure why. I've tried using the guides and changing the settings, but I just can't seem to find a satisfactory setting in S3D. I really kind of wish I hadn't spent the $140 on it. I was thinking the custom supports feature would be great, but I find myself not using it, because it doesn't print the supports exactly as pictured. I haven't tried makerware yet - does it work well with the powerspec printers?
12-31-2014, 12:13 PM #2
03-15-2015, 03:23 PM #3
Hi All,
I use an Ultimaker 2 at work along with a very high end Stratasys. I purchased a PowerSpec Pro for home after reading this post (and others). I did get the great $799 sale price at Microcenter. The machine gave me much troubles with PLA, which in the end was due mostly to the lack of cooling fan, once I started printing ABS I fell in love with this machine. I upgraded the fan using http://www.thingiverse.com/thing:537918 this one fit best with the PowerSpec Pro trapezoid shaped x-slide. This is the only way to print PLA and it works awesome with ABS too.
I had been using Cura for artistic models and slic3r for mechanical parts, but after reading this article http://www.3duniverse.org/2014/01/05.../#comment-6403 and updating the g-code posts I find that slic3r gives very good quality prints. This is due to slic3r allowing me to set extrusion width as a percent of layer thickness. Setting some values to 100% or less forces the extruder to extrude smaller widths than the 0.4mm nozzle which leads to smooth surfaces.
Regards,
