05-22-2017, 11:57 PM #1
No! Stay with bugfix_v1.1.0 That has a lot of good stuff that is not in v1.1.0 Please put bugfix_v1.1.0 back on your machine. And do the 'Quick Start' sequence here:
(You can skip the manual probing -- G29 P2 because the G29 P3 is smart enough to handle the unprobed points now.)
https://github.com/MarlinFirmware/Ma...ed_leveling.md
Probably the source of the problem for this:
Followed your guidance here step by step (G29 S1, G29 F10.0 + M500) still it returns "Unified Bed Leveling System v1.01 inactive." for a "G29 W" after a reboot followed by a G28. Is it supposed to be like that?
READ: Error:EEPROM checksum mismatch - (stored CRC)33233 != 64164 (calculated CRC)!READ: echo:Hardcoded Default Settings Loaded Hardcoded Default Settings LoadedLast edited by Roxy; 05-23-2017 at 12:21 AM.
05-23-2017, 07:07 AM #2
- Feb 2015
- Brazil
- 26
Out of much respect for your work here I've downloaded the updated files and went on to configure each parameter, flash, test M500 with some changes just to see if anything would stick or break the CRC... Step by step.
I had the new and previous (RC bugfix) configuration.h open in compare mode.
And it works... Don't ask me why b/c in the end both files look very very similar, with the exception of something you changed around line 891
Code:From: #define UBL_G26_MESH_EDITING // Enable G26 mesh editing To: #define UBL_G26_MESH_VALIDATION // Enable G26 mesh validation #define UBL_MESH_EDIT_MOVES_Z // Sophisticated users prefer no movement of nozzle
Why it was failing CRC still a mystery to me. Now I have re done G29 P1 + G29 P3 T + G29 S0 + G29 A + M500 and everything seems to be surviving boots just fine:
Code:Printer is now online.echo: External Reset Marlin bugfix-1.1.x echo: Last Updated: 2017-05-04 12:00 | Author: (none, default config) Compiled: May 23 2017 echo: Free Memory: 2787 PlannerBufferBytes: 1232 echo:V38 stored settings retrieved (453 bytes; crc 18979) Unified Bed Leveling System v1.01 active. Unified Bed Leveling initialized. Mesh loaded from slot 0 Mesh 0 loaded from storage. echo: G21 ; Units in mm echo: M149 C ; Units in Celsius echo:Filament settings: Disabled echo: M200 D3.00 echo: M200 D0 echo:Steps per unit: echo: M92 X80.00 Y80.00 Z400.00 E100.00 echo:Maximum feedrates (units/s): echo: M203 X300.00 Y300.00 Z5.00 E25.00 echo:Maximum Acceleration (units/s2): echo: M201 X2000 Y2000 Z20 E1000 echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel> echo: M204 P2000.00 R2000.00 T2000.00 echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk> echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00 echo:Home offset: echo: M206 X0.00 Y0.00 Z0.00 echo:Unified Bed Leveling: echo: M420 S1 Z10.00 Unified Bed Leveling System v1.01 active. Active Mesh Slot: 0 z_offset: 0.000000 EEPROM can hold 8 meshes. echo:Material heatup parameters: echo: M145 S0 H180 B70 F0 M145 S1 H240 B110 F0 echo:PID settings: echo: M301 P22.20 I1.08 D114.00 echo:Z-Probe Offset (mm): echo: M851 Z-5.00 echo:SD card ok
It looks like I'm good to go... right? The only thing I don't see here and get no response on setting is the G29 F10.0, is there a way to check if it's stored and working?
LOOKS GOOD ROXY! I'm sticking w ya brother!
Thanks again and let me know if I can be of any help with the project. I'm no C programmer but can do testing and language files to portuguese
