Results 1 to 10 of 18
11-28-2015, 06:05 PM #1
- Nov 2015
- 21
No response yet? I didn't think my questions were that complicated. What I really need to know is how thin can I make my tablet holder and how narrow can I make the perimeter section and crossbeam sections. I don't know if these are the best terms, but I think the picture makes clear what I'm talking about. I am considering nylon, but since my last post, I've also been thinking about aluminum. I did several Google searches, but cannot seem to find any info as to weight-bearing strength of these materials. Perhaps I don't know the right terms since my engineering background is essentially nonexistent.
11-30-2015, 02:45 AM #2
As I already said ... ABS is not a good choice : as it has a high shrinkage ratio, it warps. Since you intend to make a flat wide part, it is not a smart material choice. Tritan, PETG and nylon are Ok choices, it's mostly about what you have at hand.
Regarding why we are not giving you a solution : the results depend on several branching choices you have not mentioned. You don't need to be an aeronautics engineer to know this : you can trade thickness (to a point) for infill rates, the number of shells weighs in, sharp corners create weak areas ...
But then, your requirements are somewhat blurry. What do you want it to stand to ? What is the max authorized static deformation ... ? What is the load case ?
So, unless you ask with proper engineering parameters, you don't get an engineer answer. ;-)
As a starting point, and given the the overall idea, I would advise you to :
- put a 5mm thickness on your "lateral supports"
- put 10mm on the base thickness
- put 1,5mm of shell thickness
- put 25% infill.
- add 5mm chamfers in all corners
I think there's 95% chance it will work. You want it slimmer & sexier : make iterations, ask with a clear specification or pay for a design. With the new surface 4 out the door, I'm pretty sure people will make stuff. I for one know I'll have to prepare something for my wife. Tell you in 2 months.
As for aluminium : good point but at this time, given your design, better get it machined than 3D printed. Also the cost compared to nylon won't be competitive, and compared to a plastic part that can be honeycombed, it will be heavier.
11-30-2015, 01:40 PM #3
- Nov 2015
- 21
I'm not that familiar with much of the 3-D printing terminology yet, so I don't quite understand everything you said. I have created another design where I have indicated the thickness of the sections, just to make sure that we are talking about the same thing.
As far as shells and infills are concerned, is there a scaling principle involved based on the thickness of the material? For example, I read an explanation of shells and infills, and based on the example pictures of a cube measuring 1 cubic inch, three shells appeared to be only a millimeter thick. And a 25% infill appeared to have chambers/cells that were about 2 millimeters across. Now, I can understand using three shells for my design if the vertical thickness is 1.5 millimeter, but with 25% infill, I don't quite see how that would work. So that's why I was wondering if the size would be scaled down. Maybe I'm misunderstanding something.
11-30-2015, 03:52 PM #4
11-30-2015, 04:58 PM #5
- Nov 2015
- 21
