02-17-2020, 01:58 PM #1
right this is where it gets complicated :-)
There are possibly hundreds of types and formulations of 'nylon'.
I have found 2 that work reasonably well in an unenclosed printer.
MyMat nylon from spain and taulman 645 https://taulman3d.com/645-features.html
http://www.mymatsolutions.com/
Every other nylon I have tried has been an abject failure.
Hell every other taulman filament I've tried has been impossible to use outside a heated enclosure.
But nylon 645, is pretty good.
So while the heated enclosure would help - it's not strictly necessary with the right material.
And yes, the hairdryer and enclosure should work quite well.
Throw in a thermostatically controlled switch for the dryer and you've got a temperature controlled build volume :-)
Obviously everything else inside the volume is getting heated, so that can throw up issues if you have it too hot - so personally I'd always go the thermostat route.
02-25-2020, 04:48 PM #2
- Aug 2015
- 256
I heat my enclosure just like this, and I and attest it works great... just make sure the hair dryer is not pointing at the build area.
I also agree that you should look for a printer with a direct drive extruder: better precision and can print flexible materials (nylon is semi-flexible).Also look for a printer with an all-metal hotend, so you can print over 240C without problems.
