Results 11 to 20 of 20
11-26-2015, 10:50 AM #11
- Burnley, UK
- 1,662
Google is wrong. I only use Cura and have no problems at all.
You need to bear in mind that people do not make forum posts stating " I am using Cura and it is working perfectly".
11-26-2015, 10:55 AM #12
Ok,
Thanks you very much for he input.
Now that you've told me that you are using Cura GCode with your FFCP I'm going to try it.
REALLY appreciate your help this morining
I'll post back my results later.
11-26-2015, 11:00 AM #13
Well,
Right off the bat I got some errors after importing the Cura G-code and attempting to create an X3G file....
[12:01:22] Unrecognized MCode! M190
[12:01:22] Unrecognized MCode! M82
[12:01:22] For axis 0, maxFeedrate=18000.0, stepsPerMM=94.139704DDA:35
[12:01:22] For axis 1, maxFeedrate=18000.0, stepsPerMM=94.139704DDA:35
[12:01:22] For axis 2, maxFeedrate=1170.0, stepsPerMM=400.0DDA:128
[12:01:22] Unrecognized MCode! M117
[12:01:23] Unrecognized MCode! M84
[12:01:23] Finished writing to file!
[12:01:23] Done building.
11-26-2015, 11:04 AM #14
Ok
I think I can fix these they are in the header
M190: Wait for bed temperature to reach target temp
M82: Set extruder to absolute mode
M117: Get Zero Position
M117: Display Message
M84: Stop idle hold
11-26-2015, 11:15 AM #15
Just found this.....the motherlode of Makerbot Gcode information !
http://reprap.org/wiki/G-code#M109_in_MakerBot
11-26-2015, 05:07 PM #16
Found the solution.....The latest version of ReplicatorG would not work.
The last version works fine
11-27-2015, 08:37 AM #17
Cura is Not compatible with our CTC-Bizer either .
Cura created files are Not readable by firmware.
I don't remember any file size differences like that when I was using Rep-G.Last edited by EagleSeven; 11-27-2015 at 08:43 AM.
11-27-2015, 08:51 AM #18
11-27-2015, 08:55 AM #19
11-27-2015, 03:12 PM #20
Yessir..
I was beating my noggin against the wall until I decided to give the last version a try and then it started working.
When I tried to put my header code on a Cura generated file, it didn't work and my printer made some awful noises so I nixed that real fast.
I finally got my Simplify3D license back working so I'm going to just stick with S3D for now.
