Results 1 to 10 of 13
Thread: CTC printer settings
02-02-2016, 09:31 AM #1
- Dec 2015
- Seattle
- 38
It's the tool head offset (For those wondering I mean the distance between the extruders) . When I updated to Sailfish, all of my home axis remained, but my tool head offset had been set to 0, so when the printer used the left nozzle it went way left and started clicking before attempting to print.
02-02-2016, 11:12 AM #2
If I remember correctly there is a Firmware setting to select which nozzle is #0 and which is #1.
(new firmware may have the nozzles Reversed ? )
So, maybe if you switch those it will fix the startup location and keep them over bed-plate ?
Then select the correct nozzle in slicer software as primary (#0) and secondary (#1),
to select which to use when printing.Last edited by EagleSeven; 02-02-2016 at 11:41 AM.
02-03-2016, 01:49 PM #3
- Dec 2015
- Seattle
- 38
I've already worked out the issue, I was simply explaining what the setting was. This offset being set to 0 is a common problem upgrading to Sailfish in CTC printers. If you do a little googling, you'll see others with the same complaints. The reason I put the value 34mm instead of the other values you had listed was because his symptoms had matched mine from my update.
If you find that firmware setting, that would be great, as most software likes to default to the right extruder head, and I can't get my extruders level to each other so I primarily use the left.
