Results 51 to 60 of 71
Thread: Einscan-S initial review
04-03-2016, 03:23 PM #51
- Jul 2014
- UK
- 124
To be honest, the projector and webcam only cost me £100. The David software is £300 so for £400 I could have a complete SLS setup.
But like I said, there's more work involved with David and it's more time consuming so I'm happy to pay extra for the Afinia to reduce all that and still achieve good quality scans.
04-03-2016, 05:53 PM #52
- Jul 2015
- 15
For mesh simplification I use Vizup http://vizup.com/products.html. I also use GOM Inspect (brilliant piece of software), Meshmixer. But Vizup I find keeps the geometry and shows you 10 different reductions to choose from.
04-08-2016, 10:04 AM #53
- Jul 2014
- UK
- 124
04-08-2016, 11:55 AM #54
- Aug 2015
- 241
The filesizes can get pretty large fast,
I let the scan software optimize the mesh data 50% (for large objects), then open in Rhino3D en let the software do a reduce mesh,
keep the slider on higher accuracy, and reduce between 30% and 60%
objects with a lot of smooth surfaces can be reduce more, and if it has more details I just do a few tests until I can visually see a difference.
I still have to test meshmixer, to see what size difference I can get
https://www.youtube.com/watch?v=921cDYBpuL4
04-08-2016, 12:30 PM #55
- Jul 2014
- UK
- 124
Thanks, didn't know Meshmixer could do that.
So you use the "Simplify" option in the scan software first ?Last edited by scobo; 04-08-2016 at 03:30 PM.
04-08-2016, 02:05 PM #56
- Aug 2015
- 241
The "simplify" option is also a mesh decimation option,
I only do it with large objects, this makes more easy to import into Meshmixer or Rhino3D.
depending on what kind of object you scan, you want to keep more control if you are going to reduce the mesh (if you want or need to),
and the "simplify" doesn't show you a preview how it will look after decimation.
Meshmixer gives you more options and a preview before accepting the settings
04-08-2016, 02:30 PM #57
- Jul 2014
- UK
- 124
I've been playing around with Meshlab, the simplication filter does a pretty good job of reducing a mesh.
I can't see any difference in quality at 50% reduction and of course, it cuts the file size in half.
04-11-2016, 03:58 PM #58
- Jul 2014
- UK
- 124
After a few days playing around with it, I've got to say it's an excellent bit of kit !
The auto alignment really is fantastic, way better than any other software.
Still trying to find a way round the hole filling though. Anyone have a way of dealing with this ?
04-12-2016, 02:55 AM #59
- Aug 2015
- 241
They would need to adjust thee software, and I wonder if the Pro version has this option ?
Do you have trouble with the hole filling ?, I just keep on scanning until I can't see any holes in the preview before completing the scan.
and only have alignment problems once in a while
04-12-2016, 03:08 AM #60
- Jul 2014
- UK
- 124
I find the software sometimes fills in too much of the scan and fills areas that shouldn't be filled.
This was mentioned in another thread but I don't think a full solution was given.
