Results 11 to 20 of 57
07-19-2014, 09:03 AM #11
07-19-2014, 09:11 AM #12
07-19-2014, 10:50 AM #13
Auto leveling isn't needed at all. Too much involved in doing it right and would cost too much to make it worth it. Leveling and setting the gap isn't a big deal at all really.
07-19-2014, 02:22 PM #14
what does it mean when the front, back and sides feel right but the center is tight?
07-19-2014, 02:36 PM #15
07-19-2014, 03:13 PM #16
Basically, you change your Marlin firmware to have auto bed leveling turned on. The only other thing you do is get a cheap servo off of eBay to kick down a leg with the Z-Limit switch on it.
If you can run a Wade's extruder on your machine, check out: http://3dprintboard.com/showthread.p...light=Wade%27s
You will see where the probe goes and how the servo mounts into the extruder.
You would just order a servo such as this to fit into the extruder and then print up the parts:
http://www.ebay.com/itm/1PCS-x-SG90-...item4623c4e449
And if you run the Enhanced G29 Auto Bed Leveling command found here:
http://3dprintboard.com/showthread.p...ed-G29-command
You will get lots of help getting it going!Last edited by Roxy; 07-19-2014 at 03:19 PM.
07-19-2014, 03:32 PM #17
Bad idea even suggesting contraption like that to someone so new to printing 3d, and I doubt it would even fit the Flashforge let alone getting it to electronically function properly. Adding any extra weight to the print head is a very bad idea also. It just causes more wear and tear on the mechanisms and worse print quality even at lower speeds. The best thing you can do to a Flash Forge Dual head is remove the left side stepper and heater block and all the wiring especially if you don't plan on doing Dualstrusion.
Auto bed leveling would be very complicated to automate due to having to calculate 3 different heights on the build plate. Leveling and just setting z height are two entirely different scenarios.Last edited by jfkansas; 07-19-2014 at 03:37 PM.
07-19-2014, 03:36 PM #18
That is normal, the print head sags very slightly in the middle. I usually level the bed perfectly with a postit note, then every so slighty tighten each thumbscrew just a tiny amount. Do all 3 the same. But it will print fine when the print head is a little closer to the build plate.
It helps if you decrease the weight of the print head by removing the unused stepper motor at least when not in use.
07-19-2014, 05:30 PM #19
07-19-2014, 10:05 PM #20
You can do autolevelling for under $40.
Really mate, you need to stop dissing peoples responses on here or automatically assuming them incorrect or telling someone else that it's not needed.
If you have a suggestion, give it - but don't keep jumping on suggestions people give, it's getting pretty apparent now.
