Results 21 to 30 of 83
Thread: Bonded Heat bed for 12"
08-28-2015, 01:48 PM #21
What's needed here is someone already familiar with temperature control options in Marlin. For all I know, PWM control on the heater output is a simple configuration file change.
The ATMEGA2560 processor provides a number of hardware PWM channels, but each is associated with a particular processor pin. For purposes of flexibility regardless of underlying hardware, the Arduino libraries also support software-based PWM. Software PWM can be used with any pin. Software-based PWMs will typically run slower than possible in hardware, along with some cost in software overhead. Slower doesn't mean they'd be unacceptably slow. Assuming the 7 Hz rate is correct, a 7 Hz PWM frequency is still far faster than the bang-bang control loop.
More info on the hardware-based PWM: RAMPS D8, D9, and D10 are all connected to ATMEGA2560 pins that can be, at least theoretically, configured as hardware PWM outputs. When configured for hardware PWM, RAMPS D8 for the default heat bed connection is derived from ATMEGA2560 timer/counter 4, as can be the D6 servo output. Separate output compare registers for D6 (register OC4A) and D8 (register OC4C) are provided to allow the on/off ratio for D6 and D8 to be managed independently. With both derived from the same timer/counter, both D6 and D8 would have the same pulse train frequency. The other output compare register on timer/counter 4, OC4B, is associated with an ATMEGA2560 pin that is not passed to RAMPS.
How much Marlin and the underlying Arduino libraries can already leverage the hardware-based PWM would be where someone with existing knowledge would help. I know more about the AVR processors themselves than I do about Marlin and Arduino.
Understanding the internal workings of the hardware timers isn't trivial. The ATMEL datasheets are light on top-level info on how to make them work. I typically look into Arduino sketches or C-code examples on avrfreaks when I need to do something new with them.Last edited by printbus; 08-28-2015 at 02:02 PM. Reason: corrected OC4C label on D8
08-28-2015, 02:39 PM #22
- Apr 2015
- Lakeport, CA.
- 174
It appears as though Marlin does soft PWM (at least that's what it looks like in temperature.cpp), and that it is easy to enable HE and HB PID independently. Per your comments about non-trivial hardware usage, it looks like the minimal cpu overhead for an acceptable and universal PWM solution is the way they went.
08-28-2015, 06:44 PM #23
Soft PWM would make sense, since although the MEGA2560 board used in our case has a number of hardware PWM channels, not all motherboard types would. I wouldn't be surprised if one could find a hardware PWM library to use though, similar to the way there are fast I/O libraries that leverage underlying hardware more efficiently than vanilla Marlin does.
I didn't mean to exaggerate the complexity of the hardware PWM. My point is that for someone not familiar with them, the hardware timers/counters can be daunting because of the extensive amount of flexibility ATMEL built into them.
08-28-2015, 08:09 PM #24
- Apr 2015
- Lakeport, CA.
- 174
Understood..., and thx for the specific pointer to an SSR.
When I have an excuse to unseal my next spool of PLA..., gonna give it the blue tape vs heated bed test. And for sure..., a trip to Amazon for a new metric dial indicator is in the works.
And heck..., the SSR is probably worth it, even in bang-bang mode, just for the quiet.
08-28-2015, 08:28 PM #25
- Feb 2015
- 211
08-28-2015, 08:36 PM #26
- Feb 2015
- 211
I did this test with my printer last week. The Z banding was much better but I still had a periodic Z band spaced at ~.8 mm so to me that indicates that there is still some issue with hardware as .8 mm is the pitch of the threaded rods.
The banding with the heat bed on is horrible so I know that the heat bed is causing the majority of the issues.
I am just going to go down my list of things and try to get it taken care of, too many people are having banding issues with the 12" printers so there has to be some inherent issue with the design/components used in them. I think we will find it is a combination of things that are stacking up and causing the problems.
08-28-2015, 09:31 PM #27
- Apr 2015
- Lakeport, CA.
- 174
08-28-2015, 10:37 PM #28
- Feb 2015
- 371
Here is where I am getting confused. My current setup is a Rumba which sends a 12 volt voltage to the relay to open and close letting higher current flow through the relay. This isn't a PWM signal. Can one simply reconfigure the firmware to send the appropriate signal to a SSR via the same wiring or is a different approach required.
08-28-2015, 11:10 PM #29
- Apr 2015
- Lakeport, CA.
- 174
From looking at configuration.h and temperature.cpp, it would appear that the answer is yes.
Looking at the Makerfarm Configuration.h, it's sorta interesting though.
here are some comments from the file:
// Bed Temperature Control
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT above is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
Which is weird..., cuz it sure seems to ACT like some kind of hysteresis is being accounted for..., but I guess not.
SO..., it might be worth a shot enabling "BED_LIMIT_SWITCHING" if it enables a mechanical relay friendly form of hysteresis management.
Otherwise..., PID + SSR seems to be the way to go.
Of course..., your mileage may vary...
08-29-2015, 12:09 AM #30
- Feb 2015
- 211
Here is a picture, I am sure you can guess what one is with the heated bed on.
These two were printed with the exact same settings on both, except the one on the left is with the heated bed on the one on the right is with the heated bed off. As I mentioned earlier even with the bed off I still have some periodic banding at .8mm intervals.
