Results 1 to 10 of 15
06-22-2015, 05:36 PM #1
- Sep 2014
- 28
I took some pictures. I don't see anything wrong. Could it be the wire that heats up the nozzle, its next to where the motor would go. You can see in picture.
http://imgur.com/a/H9J9F
06-23-2015, 01:27 AM #2
- Sep 2014
- 19
sapient24,
thank you for pictures, I found the issue:
1. change your fan to the original one, and don't use cheap chineese junk, because it could lead to such problems.
2. your fan is looking the wrong way, so instead of blowing to the heat sink and cooling it, together with the bar mount and the motor, it sucks up the air from the heat sink and increases the heat inside your assembly.
Solution: Buy new fan from makerbot, mount it with the sticker looking inside and you should be good.
On a side note, you dont need any spacer between motor and bar mound to keep it cool, motor should be firmly attached to the aluminum block using 2 long screws which also attaches the fan and the heat sink to the whole assembly.
06-23-2015, 02:05 AM #3
- Sep 2014
- 28
Thanks for your response Sinful.
Ya, I only plugged in that fan for a few seconds. It didn't work. It's a 12v fan. I already ordered the fan form makerbot.
I tried to let a the printer run and I'm back to getting extruding problems. Randomly starts extruding less during the print and has a tocking sound. The moter couldnt push or pull the filament.
