Results 1 to 10 of 12
03-20-2014, 02:25 AM #4
- Mar 2014
- Vienna
- 47
Hi Pom,
good to see that you´re making progress!
First of all I would like to know which printer board you´re currently using. I wouldn´t recommend a heat bed control seperated from the printer electronics since I don´t know any software supporting such a feature. Usually the temperature of the hotend AND the heatbet are set automatically at the beginning at any print job and afterwards both will be swichted. I wouldn´t want to loose that funktionality.
I think many of us using the Aduino Mega (or a clone of it) together with RAMPS board. There is a good documentation available for this combination. Firmware could be Marlin which is good described as well.
New member with print issue
