Results 1 to 10 of 19
09-20-2016, 03:31 PM #1
- Sep 2016
- 12
Why is my build plate z level getting messed up
Hi,
so when I am trying to print this:
http://www.thingiverse.com/thing:547580
I am using Makerware to export x3g to the sd card for my printer, I load it and start priting. Everything goes really well until I get to like 30-40% where my extruder does not touch the actual part:
How can I fix this, I have already tried this print like three times and I am getting the same issue
09-20-2016, 06:25 PM #2
I can see your support in the front is really stringy/not fully solid. This points to an issue with the extrusion settings or your nozzle could be clogged/need replacement.
Support structure should be completely solid lines and you may need to re-calibrate your settings for extrusion or perform maintenance.
09-21-2016, 05:05 AM #3
- Sep 2016
- 12
Thank you for your response. I don't think it is the nozzle because it is a new printer. I wanted to ask you if you recommend any specific settings for support structures?
09-21-2016, 06:53 AM #4
- Jun 2016
- Oklahoma
- 904
I would suggest starting with a good releveling of the bed. I am guessing there may be to much gap with the nozzle.
Also what material are you using?
09-21-2016, 12:18 PM #5
09-21-2016, 04:40 PM #6
- Sep 2016
- 12
I am printing with PLA, I tested it again with another print with supports and without supports. Every time I print with supports this problem appears, but without support it prints perfectly. Does anyone recommend any settings for Support structures on MarkerBot or does anyone know what I am doing wrong with supports?
09-21-2016, 05:23 PM #7
- Jun 2016
- Oklahoma
- 904
09-21-2016, 06:05 PM #8
- Sep 2016
- 12
I have seen Makerbot printers work perfectly with supports but it is my first time using a QIDI, for some reason every time it gets to the support the printer starts printing midair, like it didn't place the supports but the building plate keeps going down:
In other words, the print goes flawlessly, but as soon as it reaches the support structures, the extrude slowly starts to print midair. No idea why
This are my support settings:
I can't figure out what it is that is messing my print when I use supports.Last edited by fontseeker; 09-21-2016 at 06:15 PM.
09-21-2016, 06:18 PM #9
- Jun 2016
- Oklahoma
- 904
Some one can correct me but look a the support margin, support to model spacing and support to roof. Seems like the first or second one could be to big. In S3D the separation between the support and lower is 1 layer thickness and same for the top. Also 220 and 80 are on the upper end for PLA.
09-21-2016, 06:26 PM #10
- Sep 2016
- 12
