Results 3,201 to 3,210 of 4110
09-19-2016, 08:09 PM #3201
- Jun 2016
- Oklahoma
- 904
With further testing - ABS with retraction settings of 1.4 and speed 50mm/sec with 0 restart and I get a near perfect seam.
Testing PLA with the same except -.25 restart. -.3 was a bit to much.
I wonder why ABS acts so different then PLA? I mean I get that they are two different materials but why does the print plop out the extra at the start of an extrusion and doesn't for the ABS? Is it the viscosity of the material? Maybe I am a little to hot on the PLA (210)?
09-19-2016, 08:19 PM #3202
09-19-2016, 08:21 PM #3203
- Jun 2016
- Oklahoma
- 904
09-19-2016, 09:13 PM #3204Editor in Chief
Bitsonline
09-20-2016, 07:32 AM #3205
- Jun 2016
- Oklahoma
- 904
09-20-2016, 07:38 AM #3206
- Jun 2016
- Oklahoma
- 904
Ok, so I printed this duct last night. http://www.thingiverse.com/thing:1597507
Looks ok sitting on the bed! Later I will see how it really came out. Only thing I am worried about is getting all of the support material out of it! Hopefully it will be easier than I am thinking.
Has anyone tried this one http://www.thingiverse.com/thing:1716089 Single, uses existing blower, improved ductwork for left blower.
or the original it was designed from? They claim prints come out much better.
I am looking for a dual setup to try a dual extrusion print.
09-20-2016, 10:10 AM #3207
- Feb 2016
- 360
09-20-2016, 11:08 AM #3208
- Jun 2016
- Oklahoma
- 904
09-20-2016, 11:54 AM #3209
- Feb 2016
- 360
09-20-2016, 12:30 PM #3210
With that extruder plastic I have printed as fast as 60mm/s with a specific combo of components. Jfkansas plastic, the older style drive gear that has teeth from end to end. Teflon lined thermal tube, and a P-3d coated brass nozzle. I haven't been able to replicate these speeds with anything else.
Currently since I am out of P3-d nozzles I am using a Microswiss all metal nozzle, that is mated to a stock thermal tube with PTFE. The PTFE is cut short and inner edge beveled and stops at the top of the Micro Swiss nozzle. Slow speed printing with this, around 30mm/s. But outlines and infill are set to 100% so everything prints at this speed.
New member with print issue
