Results 3,191 to 3,200 of 4110
09-18-2016, 09:41 PM #3191
- May 2016
- Annapolis, MD
- 523
09-18-2016, 09:48 PM #3192
- May 2016
- Annapolis, MD
- 523
09-19-2016, 09:12 AM #3193
- Jun 2016
- Oklahoma
- 904
Does anyone know if the QIDI Tech-1 board will support two independent cooling fans? We have one on the left but can we control one on the right also?
09-19-2016, 09:25 AM #3194
09-19-2016, 09:42 AM #3195
- Jun 2016
- Oklahoma
- 904
09-19-2016, 10:24 AM #3196
09-19-2016, 05:11 PM #3197
- Sep 2016
I purchased one of these over the weekend. Had a couple of issues initially. The heated bed worked intermittently and the turbo fan didnt run at all. I found two faulty connectors after tracing everything back. I've attached a picture of the shorted connector (internal leafs were too wide). Fortunately I found a good electronics shop in Tucson that had the connectors. Saved me having to jury rig it. You can see where it was arcing and melted the plastic housing.
09-19-2016, 06:11 PM #3198
09-19-2016, 06:45 PM #3199
- May 2016
- Annapolis, MD
- 523
Yes, of the blower systems I had posted I have actually tried the first and third I listed (copy below). As you had mentioned that the design you favored required that you purchase a second blower and a power splitter, I inferred you were interested in the second of the three I had posted. That particular dual blower design does reduce the Y-axis build volume, and I wanted to make sure that you were aware of that difference. The two that I have tried do not impact the build volume.
http://www.thingiverse.com/thing:1542849 dual rear uses existing blower
http://www.thingiverse.com/thing:1695189 dual rear reqs 2 x blowers on back
http://www.thingiverse.com/thing:1716089 Single, uses existing blower, improved ductwork for left blower
09-19-2016, 06:51 PM #3200
- May 2016
- Annapolis, MD
- 523
