Are you referring to the Mean or Standard Deviation?
Hi
The mean is simply whatever the nominal offset to the probe was. The standard deviation is what tells you about the repeatability. Assuming you did a few dozen trials, the SD looks pretty good. If it was over a small number of trials, you need more data.
