Results 1 to 10 of 42
09-13-2016, 08:52 AM #5
- Jun 2016
- Oklahoma
- 904
WOW, full attack mode on my suggestions. That's what I get for trying to help?
He said it was a "FFCP" not a "FFCX" thus it came with Flashprint - at least mine did.
I asked about the USB since mine was problematic on a USB 3 port but fine on a USB 2 and if he is printing from a card then that is ruled out. When I turned off power management on all USB ports things improved and I am able to use the USB 3. The point is to rule out possible communication issues.
I have had filament "snag" or rather the spool was dragging after time due to the spool changing position and rubbing on the holder and it simply stripped out the filament and no "clicking".
And since you feel the need to pick my efforts to help apart, he already stated that it is having the issue on BOTH extruders so using the "other" one would seem pointless.
