Thread: homing X Y axis off set
08-17-2016, 09:36 AM #1
- May 2016
- 7
after running bed leveling through the LCD menu the X and Y axis on my Pegasus are now off setting by 20mm after homing and refuses to reset back to 0, anyone got a solution?
08-17-2016, 11:05 AM #2
- Burnley, UK
- 1,662
G92 x20 y20
08-17-2016, 11:12 AM #3
- May 2016
- 7
nope doesn't change a thing
08-17-2016, 11:23 AM #4
- Burnley, UK
- 1,662
Well if that doesn't work you either have a faulty micro or some other serious fault. That command does not move the heads it just resets the current position to 20,20 so that the 0,0 position will be -20mm from where the head currently is. Nothing will move or happen when you send the command.
08-17-2016, 11:47 AM #5
- May 2016
- 7
yep know what the G92 command does, gave up trying to sort it and just loaded the eeprom failsafe, but have yet to figure out why bed leveling has that result
