Results 2,711 to 2,720 of 4110
08-10-2016, 09:10 AM #2711
- Jun 2016
- Oklahoma
- 904
08-10-2016, 09:26 AM #2712
08-10-2016, 09:44 AM #2713
- Jun 2016
- Oklahoma
- 904
This is one of those "never thought about it" questions but I guess the first layer settings would affect the print even if you didn't have a "bottom" layer.
Once I get this thing back together and hopefully working again, I will get back to tackling this height issue!!
08-10-2016, 10:15 AM #2714
- Jun 2016
- Oklahoma
- 904
What are you guys using to lubricate the QIDI? I bought sewing machine oil because I thought someone said that was good. I am concerned I may have issues with the Z axis rod being a bit sticky. I think that before it was contributing to a layer shift.
The "bearing" on the build table for the "threaded" rod seems like it has up/down play in it. The bolts are tight.
08-10-2016, 10:15 AM #2715
There is always a bottom layer, even if it is just an outline. So if it is set to 50% then first layer would be .2mm which is .05mm off from what you are short. And .05mm is acceptable 3d print error, heck .25mm is acceptable 3dprint error even. Most objects you will never notice -.25mm.
08-10-2016, 10:18 AM #2716
Up and down play in the threaded rod isn't a big deal, the platform weight and gravity hold it down.
You want to use some grease on the linear bearings, not oil. I have a custom mix of some light Mystic lubes grease + 3n1 oil to thin it out a little. A lot suggest SuperLube sillcon but I like my mix better.
08-10-2016, 10:41 AM #2717
- Feb 2016
- 360
I am having some serious issues.
Had a print mess up few days ago..made a mess. As a result my left side is unusable...probably have to replace the heating core.
Now I can't get right side to print. Will be fine for few hours then stop extruding material. Have done everything. Changed driver, changed the stepper, cleaned everything, even tried with a new nozzle/ptfe tube. No matter what I do it will print a few hours then stop feeding materials.
I am stones throw away from getting rid of this thing...maybe getting a I3 clone.....
edit:
Could sell this one for $600-700 and get 2 I3 clones. If the hype is real about that new raptor stuff from MG what is point of working in ABS anyway right? I just don't know what else to do here. I have literally tried everything I can think of. I have slept maybe 8hrs in the past 4 days. Have wasted around 800grams of material. Nothing works!Last edited by Syd_Khaos; 08-10-2016 at 11:21 AM.
08-10-2016, 11:49 AM #2718
- Jun 2016
- Oklahoma
- 904
08-10-2016, 11:51 AM #2719
- Jun 2016
- Oklahoma
- 904
08-10-2016, 11:56 AM #2720
- Feb 2016
- 360
