Are you trying to simply submerge the part ?( = it's inside the tank) -- or-- are you trying to use the part to stop water flow? (= it's a stopper or gasket).
They are parts that normally stay underwater in the tank. It won't be used as a gasket (which will remain rubber), or I might consider a flexible filament for that.
