Thread: please help 3d printer delta
07-31-2016, 11:08 AM #1
- Jul 2016
please help. I lose on the next day. the printer is new. just made up according to the instructions. Problem setting bed. one engine is not going up and buzzes. in settings, you can move it. how to fix it?
my printer is Geeetech Rostock mini G2S .
here is my problem:
https://youtu.be/r26j1kd5WfA
07-31-2016, 12:09 PM #2
- Oct 2015
- South Yorkshire
- 15
Here are a few things you should ask yourself.
Disable steppers and check all three slides move freely?
Check you haven't put your stepper wires anywhere near your limit switch wires (they interfere and cause problems, they should be kept away from each other)
Check your limit switch functions properly (via a test meter, and your software too) and also check your have the correct locations (X switch, is X, Y switch is Y etc)
If your sure it not a problem wires interfering or limit switch communications,
swap the cables with a different motor that you know works - is the problem with the motor or the controller?
If its the motor, Check all three motors are the same brand and model?
check resistance/continuity between coils on your stepper?
If it's the controller, check the firmware setting - for the motor current etc.
07-31-2016, 09:17 PM #3
- Jul 2016
- Pennsylvania, USA
- 255
Hi
Check to see that all 4 of the stepper wires on the buzzing motor are hooked up. If you only hook up 3 of the 4 wires, the motor will buzz and not turn.
Bob
08-01-2016, 04:45 AM #4
- Jul 2016
everything works correctly as it enters the manual control. You can normally move up and down each engine, but it can not be calibrated, during calibration moves like in the video
Moderator note: Late post due to unexpected delay in obtaining moderator approvalLast edited by printbus; 09-17-2016 at 12:28 PM.
New member with print issue
