Thread: Versa3D Kickstarter
07-21-2016, 06:15 AM #3
and you need to add a mount for a vacumn hose when milling. You don't want all that crap flaoting around inside a 3d printer or laser engraver.
It seems to be the biggest issue I've seen with these all-in-ones - and there are quite a few around now. Nobody has allowed for a vacumn fitting.
Yes you could easily design and print your own - but come on it's standard on any industrial saw or cutter. It should be on any machine that includes milling.
$3.499 ! for something that uses off the shelf aluminium 'tubing' for most of it's structure. ie: cheap parts.
And that's a limited cheap option.
Looks like final retail porice with all three heads is going to be closer to $5000.
And you're into similiar price brackets as the hyrel there. Very stiff competition.
I predict you're not going to sell many of these.
You need to look at the other systems offering the same thing and price nearer those. basically anything much over $3-4000 is going to be too high.
It also needs to have a fully enclosed housing - to improve 3d printing and stop metal or wood dust getting all over your workshop when milling.
had you floated this a couple of years ago - you might have had a chance. but there are now multiple multi-head systems around, some for very reasonable money indeed
check out the z-morph. the full kit is well under $1000 cheaper than youyrs and also includes a paste extruder as well as, printheads, milling and laser.
https://store.zmorph3d.com/produkt/z...0-sx-full-set/
There are a few more around. either in the same price range or cheaper.
http://www.makerfarm.com/index.php/12-pegasus-kit.html/
12 inch cube build volume, some linear aluminium as you're using. $675 as a kit.
The milling and laser probably won't be enough to convince someone to cough up another $4000+ for something that looks very similiar. Yes you're using the gear thing not belts or screws, but again not sure how you convince people it's worth thousands of dollars more than the tried and tested methods.
I wish you good luck, but I think it'll be an uphill climb.Last edited by curious aardvark; 07-22-2016 at 06:12 AM.
