Results 2,391 to 2,400 of 4110
07-16-2016, 08:30 PM #2391
- May 2016
- Annapolis, MD
- 523
I just found this tube cutter jig, http://www.thingiverse.com/thing:1675294
It looks like it would work well and want to make it the correct length for the QiDi. The cutter's design length appears to be ~ 34.2mm.
07-16-2016, 09:49 PM #2392
- May 2016
- Annapolis, MD
- 523
I printed this thing. It needed 104% on the X & Y to fit the 4mm OD PTFE tubing that I have. It works extremely well. I get a clean right angle cut on the end and a repeatable length of 34.18 +/- 0.02mm on a sample of three tubes cut. Now if I just knew what the proper length should be...
07-16-2016, 09:58 PM #2393
- Aug 2014
- 627
07-16-2016, 10:07 PM #2394
- May 2016
- Annapolis, MD
- 523
07-16-2016, 10:15 PM #2395
- Aug 2014
- 627
07-16-2016, 10:41 PM #2396
- Feb 2016
- 360
After the first batch of wal-mart cheap glue we tried Dollar Tree glue as well. Didn't do so good.
Kinda crazy....its all called super glue but it seems no 2 are alike. I think I just lucked out with the wal-mart stuff to be honest. But on my 4th or so 4pack and its still doing good. Hard for me to judge now though as I have been finishing all my stuff a bit different since I found out wood filler bonds great to ABS.
07-16-2016, 11:06 PM #2397
07-16-2016, 11:07 PM #2398
- Aug 2014
- 627
Well, the what is crazy is the stuff in the Dollar Tree is the real deal from back in the 1970's and stuff but just does not work. Now I had read last year that Cyanoacrylate glue has expiry dates and actually goes stale fast (meaning it will not work right) so I suspect the Dollar Tree stuff is older stock but not for sure.
Remember Cyanoacrylate glue was created by Super Glue to seal the wounds of soldiers in Vietnam and at that the stuff excels. Thanks to that glue staples after surgery is no longer used (on older people who had surgery pre ~1974 you can see the staple scars) but wth? I still remember in the 1970s and 1980s that stuff glued plastic like no tomorrow but after about 2000 just didn't work as well. What I figured was the plastic was slightly changed so the Cyanoacrylate glue would no longer work as well, if at all, because if you could mend it then that is a lost future sell. With the stuff not working all that well on the filament we use I don't know what to think but I still remember when it glued everything well and not just your fingers and hands.
07-16-2016, 11:29 PM #2399
It is easier to find the right length by taking a nozzle and thermal tube and test fit a liner. You can cut it a bit long and see what the gap is between the nozzle and the thermal tube. I like to compress the tube just a bit. Leave about a .1mm gap, and this will close up when tightened together. The end of PTFE that goes into the nozzle should have the ID chamfered a little with a drill bit. Just use a bigger than 4mm drill bit and take the edge off the inside. go about .5mm deep with the chamfer.
07-17-2016, 08:14 AM #2400
- May 2016
- 55
After playing with supports, I final decided to cut one of my parts in half so both ends could face up. I'm using Krazy Glue to glue the PLA together, and it works well. The secret for me is pressing for several seconds, and then several more. It's like water right up until the point where it starts sticking, then it's really stuck. I've used it on ABS as well with the same effect, for a pendant that was two-sided.
