Results 1 to 10 of 31
07-06-2016, 03:54 PM #21
I believe the existing extruders will fit the Pegasus. The X axis extrusion spacing is the same, so you would need to print the X axis backing plate and mount the wheels and everything else to that, and you should be in business.
Unless I have misunderstood what you're looking for.
Bringing the fans around the back side is a possibility. I looked at it at one point and didn't think there was enough room to get full X travel on the i3v. Maybe it would work better on the Pegasus.
