Thread: 3D Printing Embossed Text
07-04-2016, 07:54 AM #1
- Jan 2015
- 20
Any tips for making this look better?
It was done on a flashforge creator pro and sliced with simplify. What im referring to is the area just past the text and the areas between the letters, it seems to extrude differently for a short period after the extruder turns back to the outmost shell
07-04-2016, 12:53 PM #2
I think slowing your printer down would help.
Also if possible... orientate the print in your slicer so that the text is perpendicular to the layers. (e.g facing upwards or downwards on the print bed) This would probably give the best result but its not always practicable.
07-05-2016, 06:24 AM #3
- Jan 2015
- 20
07-07-2016, 01:51 PM #4
- Jul 2016
- Pennsylvania, USA
- 255
Hi
You are trying to print right angles (yes that's obvious). Any time you do that, there is a speed up / slow down process. If your extruder / hot end do not keep up, you will get odd effects. If slowing down does not fix the issue, check your temperatures.
Bob
