Quote Originally Posted by Syd_Khaos View Post
ABS should be fine if you print it dense enough.
Any nylon that is gonna perform better in these regards than ABS is gonna be 2-3 times the cost per gram.
Taulman makes good stuff, but they are overpriced by a good but imo. Nothing but there upper line of nylon will give you better tensile, impact, or crush strength than high-quality ABS. And by time ya get into those grade nylons your paying $50+ USD for 500g spool.
Sounds great. I think I will give it a go with the ABS that came with the machine.
What brands of PLA or ABS do you guys recommend? I wrote down some of the sources I have seen on here but have to go digging for them now!
Going to order a few more rolls of PLA & ABS as I start to learn!
