06-12-2016, 06:01 PM #1
- Jun 2016
Trying to find a borosilicate bed in 220x220 format
Hey all,
Have an Alunar 3D printer, which is an Anet A8 / Prusa i3 clone with a 220x220mm bed. I'm suspecting that it's warping slowly because in the very center, its super tight vs. at the edges when I calibrate it, causing some prints to "sink" into the bed and the shell fills to be super thin on the bottom.
Curious if anyone knows of a supplier who has one in that size? I can find 200x213 / 200x220 / 200x200 all day, but nothing in 220x220.
Thoughts?
06-13-2016, 09:21 AM #2
- Mar 2014
- 223
Personally I've found that regular glass works fine as long as you put Kapton or PET film on the printing surface, I've done hundreds of prints on 2mm glass cut to size at a nearby frame shop without any damage to the glass.
06-18-2016, 10:26 PM #3
If you do plan to use regular glass, keep in mind that it is much more sensitive to temperature fluctuations. I have had issues with glass plates breaking since my custom bed heats up super fast! Now I only use 4mm borosilicate glass.
As long as you heat and cool the bed slowly you should be fine.
06-20-2016, 03:29 PM #4
- Jun 2015
- Edmonton Alberta Canada
- 8
Why dont you just get yourself a sheet of 300mm x 300mm x3mm borosilicate glass, and then buy a glass cutter and cut of the 80mm each side to fit?
Glass cutting is super easy, just get a very straight edge (preferably a square) and then gently run the glass cutter over the glass 5-10 passes, this scores the glass nicely. Then all you need to do it lift the glass no more than 1/2" up with the large straight edge beneath the score now, and gently push "evenly" down on the 'cut-off' side and it will cleanly snap off.
06-20-2016, 10:17 PM #5
- Mar 2014
- 223
