Results 61 to 70 of 84
06-09-2016, 11:31 AM #61
06-09-2016, 11:47 AM #62
- Jul 2014
- UK
- 124
No worries. Thanks for confirming my thoughts.
06-09-2016, 11:47 AM #63
- Burnley, UK
- 1,662
I don't think my cards are w-03. I have had them a couple of years. They all connect fine to my router. It is unclear to me what you are trying to do without me going off and reading lots of guides.
The best thing to do with the Toshiba software is to put it in a bin bag and forget you ever owned it.
06-09-2016, 12:08 PM #64
- Jul 2014
- UK
- 124
06-09-2016, 12:34 PM #65
06-09-2016, 01:24 PM #66
- Burnley, UK
- 1,662
well mine don't have any "W-XX" written on them at all.
I just use them as a client on a static IP and drag files to the card's web page to upload them.
06-09-2016, 02:15 PM #67
- Jul 2014
- UK
- 124
06-11-2016, 11:16 AM #68
- May 2016
- Annapolis, MD
- 523
06-11-2016, 03:01 PM #69
- May 2016
- Annapolis, MD
- 523
With the video full screen (via YouTube rather than this forum) I could read the screen text well enough to copy off and key in the missing CONFIG file parameters. Everything is working slick as you please now. I am using the FlashAir with S3D on a QIDI 3D printer and it makes for a very sweet setup. Thank you very much ServiceXP for making and posting your video, it likely saved me hours of frustration.
I did find that having the NOISE_CANCEL=2 line present in the CONFIG file seemed to kill off the FlashAir's wifi connection, but all seems to be perfectly functional without that particular line in there. It's working, so I'm not gonna fix it.
All during this install process I was throughly confused by an SSID issue. Specifically, whose SSID was being referred to by the two entries in the CONFIG file? I finally got it that both the SSID entries (and their password) in the final CONFIG file are the same, and are the one for my home router/access point. I kept thinking they were different, or the FlashAir card's...not so.
06-11-2016, 04:48 PM #70
- Jul 2014
- UK
- 124
I ordered a W-03 card but still couldn't get it to connect to my router at first.
I finally figured out the problem, my router was using wifi channel 12 but the flashair only uses channels 1-11 apparently ......
http://www.toshiba.co.jp/p-media/wwsite/flashair.htm
(see bottom of page)
So I switched the router to channel 11 and it's now working great !
Can now save directly to the card from S3D or access it from a mapped drive on the windows desktop.
@beerdart, I suspect this might be the issue you're having too.
Check which wifi channel your router is using and try changing it if it's above 11.Last edited by scobo; 06-11-2016 at 10:58 PM.
