Thread: Need Post Curing Unit
05-24-2016, 08:46 PM #1
- May 2016
Hello, I am new to resin type 3D printing. Just got a new Formlabs 2 and i am very happy with the prints but not so happy with the post curing process. I am a dentist and i am using it to print models for orthodontic aligners and for surgical guides.
My question is if anyone knows of a commercially available post curing unit that will fully cure their resin fast - in under 30 minutes?
05-24-2016, 10:26 PM #2
- May 2016
- SE Wisconsin
- 206
http://formlabs.com/support/finishin...curing-prints/
Since you are a professional in the business of doing these things, I would imagine that professional equipment is not out of range.
http://tangentindinc.com/curing-equi...-cube-100.html
This one can do formlab's recommended 405 nm UV and has a volume that should accommodate anything your printer can produce. This is just an example, there are many on the market that will suit your needs. I suggest looking around a bit after reading the formlabs page I linked above.
I would also add that you should look for units which also have temperature controls, since you are looking for faster cure times. According to formlabs warmer temperatures result in stronger parts with shorter cure time. Perhaps you could contact one of the many companies that manufacture these and see about integrating temperature controls and rotating platform.
05-25-2016, 06:29 AM #3
- May 2016
Thank you for this response.
The problem I have with the link you sent from Formlabs is that everything they are proposing is DIY stuff. I am amazed that they do not have units for sale that do the job.
I have been searching for everything else you list but cannot seem to find it. I guess i am just using the wrong keywords.
I will look into the one you just recommended. Thank you
05-25-2016, 04:37 PM #4
- Aug 2015
- 256
When I google "uv curing oven" I get a ton of hits. What's unclear is what would be ideal for the FL printer. I'd contact formlabs and ask what they recommend. UV curing is something that is very common in industrial practice.
05-25-2016, 06:58 PM #5
- May 2016
- SE Wisconsin
- 206
The formlabs link is just information. Read that to decide on what you need to buy.
