05-23-2016, 09:30 AM #1
PartsBadger - Custom Parts Made Simple
Hello all,
I wanted to take a moment and let everyone know about our company. PartsBadger is a custom 3D print to CNC machining company located in Milwaukee, WI. We specialize in converting 3D print design files and then replicating them using CNC machining. We have found thru personal experience that most machine shops do not machine one off pieces or low quantity runs. At one point one of our co-founders actually had requested ten different quotes from various machining companies. In the end only two companies responded, both saying they could not take the project on because of the low quantity. When we finally did get a quote returned, it had been over four weeks and was substantially higher cost than we could fathom. We knew there had to be a better way.
This lead to the creation of PartsBadger. We decided to make Instant Quotes, Online Ordering, No Minimum Quantity and Affordability priority.
Simply choose the amount of machining your design requires, enter your dimensions, choose your material and finish type and receive your quote, all on one screen. All of this makes custom parts ordering as simple as can be, which in turn has another effect. Simplifying the quote process help keep cost down. It is not uncommon for large companies to spend thousands of dollars just on prototype machining. At PartsBadger we have a advance pricing structure which can turn a project that would have cost thousands into one which may only be hundreds.
We are proud of many innovative design we have been able to help machine for the maker community. That is why we have specifically created our Maker Service. If you have a chance to check out our Maker Service make sure to sign up for an additional 5% off your next order. Now it is possible to create a CAD design, receive a instant quote and get custom machined parts in as little as 14 days.
