Results 1,541 to 1,550 of 4110
05-16-2016, 10:01 PM #1541
- Aug 2014
- 627
That is exactly what it is for and so far numerous people are having issues and I know bloody well my issues are from the factory (a bowed bent rod that had the 8mm rods and the Z axis acme rod on one side and the metal case on the other with no other bends) AND you pop up, suddenly, after all of the negative reports about this printer (Emily reads this group from Qidi) with a first post that was just to tell how great the printer was. 99 out of 100 times that is a shill post and maybe you are the 1 time out of 100 but it happens all over the internet all of the time (Amazon is infested with Shills and I flat out caught one and Amazon had to ban their account but I am sure they were right back with a new account).
05-16-2016, 10:05 PM #1542
- Aug 2014
- 627
05-16-2016, 10:08 PM #1543
Very nice, now that you mention it I will measure my Z-Axis rods tomorrow as I believe I recieved the 10mm version.
I'd like to clarify that from my point of view, the cooling is actually cooling the line of the print that was just laid down and NOT the extruder nozzle. Yes, I understand that cooling the filament coming directly out of the nozzle may seem important, but it is more important in my experience so far to allow the liquid filament to reach the layer without being cooled a lot and then have the fan cool the print layer that was just put down.
You are 100% correct if it's ABS.
I'd think this is why experience in acetone removal can assist greatly in allowing you to change the belt 5-10 times without replacing the plastic component due to acetone warp/degradation.
I didn't do this on the QIDI, but unless someone has other experience with belt removal I am going to do what I did in the past for other machines with belts that were super glued (didn't have optimal tooth groove for clamp):
1. Get a very small bead of acetone on the end of small syringe, apply and spread with another flat blunt item around the belt connection points.
2. Quickly wipe over-spill area except for belt connection and peel slowly until it doesn't lift anymore while also wiping extra acetone away that may have been missed in the first wipe process.
3. Repeat 1-2 more times until enough of the belt is up to where you can just destroy the belt and lift it up (small piece of belt still superglued and stays stuck) or fully remove it with some light superglue remaining on the plastic component.
4. The remaining superglue does not need to be removed, but keep in mind over 3-5x it will build up some and need superglue cleaning.
EDIT: I have some epoxy removal techniques as well that I've used, but they generally require heat above 200F and a skillful combination of acetone since the heat gun will spread the acetone further.Last edited by cncartist; 05-16-2016 at 10:14 PM.
05-16-2016, 10:13 PM #1544
- Aug 2014
- 627
Interesting if yours has 10mm too as mine is only two weeks and it has 8mm.
05-16-2016, 10:16 PM #1545
05-16-2016, 10:18 PM #1546
- May 2016
I received my QIDI last thursday and my z axis rods are 10mm.
05-16-2016, 10:18 PM #1547
- Aug 2014
- 627
05-16-2016, 10:21 PM #1548
Mine came from China, the exterior Z-Axis rods in this photo of my make (http://www.thingiverse.com/make:212522) are the same diameter. I won't speculate any further since 3 8mm rods would definitely be sufficient as would be 3 10mm rods but I will definitely measure to make sure!
05-16-2016, 10:24 PM #1549
- May 2016
05-16-2016, 10:26 PM #1550
Resin has changed after...
