Results 1,441 to 1,450 of 4110
05-12-2016, 09:51 AM #1441
05-12-2016, 10:03 AM #1442
- Feb 2016
- 360
First off, welcome to the Qidi club =P
I have never printed with Makerbot brand filament, but I know that 220c is WAY to hot for all the brand PLA I have used. PLA is VERY heat sensetive due to how viscious it becomes when melted. It's this higher viscosity that makes PLA ideal for artistic/fine detail applications, but it can be a double edged blade so to speak.
Try running your nozzle temp at 190-200c. For the PLA I have used (Qidi, MakerGeeks, and OrbPolymer) the sweet spot seems to be in the mid 190s. The picture you have provided is case n point your running to hot.
Also make sure your running the active cooling fan for PLA, though I typically dont start that till 2nd layer.
If your using paper to level your plate your best off using standard stock business card, but your ALOT better off going to Lowe's or Home Depot and spending the $5 on a set of metric Feeler Gauges. Make sure the set has a 0.4mm slat, and use this to level. The issue with any type of paper is it can fray at the edge, leading to a false reading.
What slicing software do ya use?
05-12-2016, 11:09 AM #1443
- May 2016
- 55
Has anyone tried pushing the QIDI below its specified minimum layer height? I've stumbled upon a blog post where a guy claimed he got the Flashforge Creator Pro (essentially the same machine) down to 0.05mm.
05-12-2016, 12:41 PM #1444
- May 2016
- 55
05-12-2016, 03:59 PM #1445
- May 2016
- 21
Using Makerbot slicer with the default PLA setting. This is an artificial knee I rendered in MAYA and exported as an STI. I changed the temp to 220c because that is what QIDI tech support recommended.
I'll drop it to 200c and re-level the bed with a business card and see what happens.
I already printed this at my campus using Makerbot and it came out decent.
Trying to pull off a 2 color version with the QiDi dual extruder.Last edited by vbx; 05-12-2016 at 04:06 PM.
05-12-2016, 04:01 PM #1446
- May 2016
- 21
05-12-2016, 04:42 PM #1447
- Feb 2016
- 360
They also say the best bed temp for PLA is 40c....
Qidi makes decent printers, far as I know they are not a print shop as well. If you have technical issues call Qidi, if you need help with print settings and such your better off asking other makers on forums like this.
I run most PLA prints with the cooling at 100% from layer 2 on. It really helps the material set in place fast where it should be.
Honestly I don't use PLA unless its something that NEEDS to be PLA to come out right. 90% of my machines runtime it's printing ABS.
For something like a prosthetic knee (or anything else for that matter) your gonna want more rigidity and impact tolerance than PLA will provide. For this you wanna look at higher grade ABS, or some nylon, though I don't think you can print that with stock setup.
05-12-2016, 07:09 PM #1448
Thanks for the information, I still have to try out dual extrusion myself. I agree with the others that you should try with the bed temp at ~40c and extruder temps 190-200c for PLA.
05-12-2016, 08:17 PM #1449
- Feb 2016
- 360
05-12-2016, 09:07 PM #1450
