Results 1,211 to 1,220 of 4110
04-24-2016, 09:56 PM #1211
Very nice fix!
Before I try, does anyone know if I could utilize the USB port on the back of the machine to supply up to 500mA of power to a device?
04-24-2016, 10:39 PM #1212
04-25-2016, 12:41 PM #1213
- Apr 2016
- 12
Got mine last Friday and successfully printed out a part yesterday on my first attempt!
Side note: ReplicatorG stinks. I switched over to Slic3r today and was able to generate a x3g file for a car part that ReplicatorG was messing up on.
04-25-2016, 01:29 PM #1214
- Aug 2014
- 627
Wonderful, I was wondering if Slic3r could be used but how do you get slic3r to output a .x3g file or does this machine also accept .gcode? I know I can tell Slic3r the flavor of gcode to make but it didn't give me an option to save as .x3g instead of .gcode or do we need to still use GPX to convert it over?
04-25-2016, 01:45 PM #1215
- Apr 2016
- 12
Unfortunately GPX needs to be used to convert to x3g as the machine does not accept gcode. I found a tutorial that mentions using a Perl post-processing script, but I couldn't get it to work (gotta debug that later). Currently I'm manually kicking off GPX from the console.
04-25-2016, 06:36 PM #1216
04-25-2016, 07:32 PM #1217
- Aug 2014
- 627
I notice that Qidi can be controlled via a PC/Laptop using USB but how in the world do you get to the USB port on it? I saw a picture showing the bottom of the printer (only one I could find) and the power supply was exposed while everything else was behind the metal cage. I prefer to control my printer via the USB BUT there is something I was reading about that sounds like something I want to try as well and that is this http://www.amazon.com/Toshiba-Flash-...fi+memory+card but that is in the future.
So, how about that USB connection?
04-25-2016, 08:12 PM #1218
The USB port is on the backside of the printer opposite corner from the power cord.
It's not recommended to run a print from a computer. Things like the computer crashing or going to sleep will kill the print.
Most use the SDCard it's more reliable.
04-25-2016, 08:44 PM #1219
- Aug 2014
- 627
Never had that as an issue with that setup and my printbox runs Linux.
Thank you for telling me where it was because finding an all around image of this printer is not easy.
I placed my bid and will know tomorrow if I get outbid or not. If I do I will place my order directly with them.
04-25-2016, 09:21 PM #1220
I've been running mine from a Raspberry Pi running Astroprint. I've been able to upload my files to the Pi over my network. Now my Pi is getting really slow and it is starting to take way too long to upload the files. Even when I SSH into to Pi it is really slow. I've looked into those Flash Air SD cards before and now I'm considering them again. I'll probably try to get Octoprint working before I go the Flash Air route.
New member with print issue
Yesterday, 08:57 AM in Tips, Tricks and Tech Help
