Results 1,131 to 1,140 of 4110
04-21-2016, 02:29 PM #1131
Ok man now i'm really Jelly!!!! I've been looking at Solidworks since last year. I can't get past the price. The software seems second to none. I went down to talk to a couple of sales reps but I just can't deal with the price. Not to mention the yearly commitment. If I had the money I would not hesitate to buy solidworks 2016.
04-21-2016, 02:30 PM #1132
You should definitely have no problem if you understand runout and how to compensate for it with the countersinks. That is quite a shame that you have had bad shipping issues in your area, have you ever tried to get large items delivered commercially instead of residential to try and avoid some shipping damage? Shipping it to your workplace, etc.
In Solidworks you can rotate your model to your chosen orientation after designing it, it will keep all existing relations and should be applied before the final STL export. This is something that can be done quickly after all the parts/assemblies are built and checked. Solidworks is professional design suite which I would not expect other users on this forum to have experience in unless they have utilized it for school or professional work environments. I haven't used any other CAD software in the past 10 years since I have a decent amount of experience in Solidworks, but I am willing to try another program out to see how they compare and give an overview.
04-21-2016, 02:31 PM #1133
I do that too, add a STL coordinate system before exporting.
By education I'm actually an Electrical Engineer. I started using Solidworks years ago to design 3D models of my electrical components so I could create 3D models of my circuits boards. The electrical components need to be oriented properly so they set on the surface of the PCB so I often need to change the orientation of downloaded models... its just part of the process.Last edited by KludgeGuru; 04-21-2016 at 02:38 PM.
04-21-2016, 02:56 PM #1134
- Aug 2014
- 627
Yep, but I had tried Autodesk's Autocad and I hated it. F360 is like what would happen if Maya had a baby with Autocad and I couldn't stand it. I loved Maya before they came in and ruined it (back when it was from Alias Wavefront I absolutely loved Maya). The fact that you can't even change how your mouse works is beyond stupid and the worst part was the fact I have to use key presses AND the mouse which is so archaic I couldn't take it any longer and I posted and deleted it. I hope you fare better than I did in it but if you are used to SW get ready.
I have to agree SW is beyond stupidly expensive but what kills it for most people is this locked in recurring charge nonsense. My hope is that Fusion 360 spanks DDE's Solidworks so hard that they come down to Earth and figure out that pricing structure of theirs is so 1980's and they change it.
04-21-2016, 04:04 PM #1135
- Feb 2016
- 96
Wait what? I haven't read through all the posts in this forum obviously but that's a huge claim. Simplify3D is the premier slicer software and I am sure they could come up with troubleshooting tips themselves. If they lifted some images (rather than purposely fail a print for illustrative purposes), or copied some text, they should definitely give credit. But at the same time, this is all open information. It's not like they are republishing the next Game of Thrones novel or something. I personally like that they have a one stop shop troubleshooting guide rather than having to dig through dozens of sites and forums by Googling.
04-21-2016, 04:05 PM #1136
- Feb 2016
- 96
Is there any part of the extruder or hot-end that can be swapped or upgraded on the QIDI printers? I think you can get a new Microswiss hot end but anything else? I assume not, which is kind of weird to me. The Wanhao Duplicator, for example, is a machine that costs half as much and anytime a new fancy hotend/extruder comes out, it seems like it's compatible with that printer (and others).
04-21-2016, 04:33 PM #1137
- Aug 2014
- 627
Compatibility because it is based on a Prusa I3 which is a Reprap. That is one thing I loved about Repraps was the universe was your oyster and you could get anything for them but when you get into the more expensive printers it seems the more expensive it is the more you are locked into what you purchased without a lot of engineering and tools.
By the way isn't the Qidi printer using MK8? I much prefer MK8 over the MK10 from everything I have read. MK8 I can change to whatever nozzle size I please as it uses 6mm sized hole but a MK10, from what I have read, doesn't so you need a special nozzle for it.
04-21-2016, 04:48 PM #1138
At the moment you can't use a microswiss MK10 conversion. The thermal tubes on the Qidi are bigger around.
I do make a nice extruder mount upgrade that many have, and this is compatible with the Microswiss Conversions. I also have some custom hot blocks that I modify to work on the QIDI. The Qidi uses 5mm threads on the thermocouples. I have to drill and retap bigger threads in my hot blocks. store.wmdproducts.com if you are interested. I am adding some more Qidi parts sometime. I have some build plate plastic like comes with it and some spare thermocouple also.
04-21-2016, 05:10 PM #1139
- Aug 2014
- 627
Any nozzle can work on the qidi except those made for a mk10, right?
04-21-2016, 05:54 PM #1140
Qidi uses a MK10 style extruder and uses MK10 nozzles. The latest Wanhaqo also use a MK10 style extruder.
